Found this at a church cake sale last week. I have a sweet tooth for these old cast iron grate KampKooks. I have a 2 burner but this 3 burner I could not resist. This one came with the original wrench and 2 sets of instructions pamphlets I replaced the NRV cork pip with new cork. The middle burner key was jammed so that needed attention. This model has a air valve as well as the normal fuel valve so that confused things for a while. It did not hold pressure for more then a minute. I finally realized it worked fine with that air valve closed. I may end up selling this one as my 2 burner has the AGM stand and a 2 burner is really all I need.
What a beast! Nicely done! I must admit confusion at your apparent connection between stoves you actually have a need for, and those you actually keep.
