AGM WCS3
Discussion in 'AGM - American Gas machine' started by Marc, Jul 6, 2019.
  1. Marc
    Marc Subscriber
    Oregon, USA
    For your inspection today is my second non-Coleman suitcase stove, an AGM WCS3.
    "The best camp stove money can buy." Pure marketing, of course.
    Overview of case. The photo does justice to the outside, what it doesn't show about the inside is that many areas were sticky and greasy with someone's bacon sarnie leftovers.
    Rear label once windscreen wings were folded out of the way. Slash across is mostly icky grease, not rust.
    Pump/filler cap removed, overview. The grey/gray section is actually painted or plated brass, not aluminum.
    Pump rod screws down. I didn't see a seal anywhere but I think this is a very rudimentary version of Coleman's locking pump. 20190705_175504.jpg
    Pump leather oiled and reinserted, the pump worked beautifully and pressurized the tank just fine. Soapy water sprayed on the works, with pump handle screwed down it seems to hold pressure just fine. 20190705_175937.jpg
    What about without the pump handle screwed down? That won't do! Time to have a look at the NRV. 20190705_180000.jpg
    Tight grip with a rubber work glove on the pump tube and an adjustable spanner on the NRV nut got it loose. Here's a view of the NRV seat: 20190705_180231.jpg
    To be continued, next post.
  2. Marc
    Marc Subscriber
    Oregon, USA
    NRV assembly:
    As much of a close-up as my phone will do on the NRV pip itself. Note the cross-wire in the spring, it fits into the slot visible on the side of the NRV pip holder. 20190705_180357.jpg
    Reverse side of the pip holder: 20190705_180528.jpg
    Pressed the pip holder against the nitrile sheet I had to create a ring, giving me a rough shape to cut out: 20190705_180749.jpg
    Previous pip came out with the consistency of cheese, remnants can be seen in the lower right of the photo. Replacement pip in place: 20190705_181033.jpg
    Reassembly in this order: 20190705_181156.jpg
    Overview of the burners with cap and flame rings removed: 20190705_181548.jpg 20190705_181551.jpg
    Peek inside the auxiliary burner, showing the valve controlling that burner. Here it is, in the open position: 20190705_181716.jpg
  3. Marc
    Marc Subscriber
    Oregon, USA
    Here it is, in the closed position:
    Model stamp, and grunge: 20190705_182320.jpg
    Interesting feet, they pull straight down and click into slots in the side of these sleeves. Here visible in the extended position and locked into place: 20190705_182616.jpg
    A quick squeeze of the two vertical pieces allows the foot to be pushed into the body of the stove: 20190705_182627.jpg
    Upon pumping for test firing, the fuel cap/pump tube started leaking fiercely despite sealing just fine previously. The O-ring was rock hard. D'oh, I know better, should have checked that. Here it is, replaced with an O-ring from an assortment I had on hand. 20190705_183004_001.jpg
    Holding pressure amid soapy water just fine, it's now go-time: 20190705_183212.jpg
    Auxiliary burner: 20190705_183618.jpg
    Whatever shall I do with a running stove? Got that one figured out. (Yes, I put the lid back on the perc basket before closing it up.) 20190705_184831.jpg 20190705_184902.jpg 20190705_185052.jpg
    Stove still needs a good cleaning, but otherwise it's good to go.
    Glad to finally get some stoving in. Thanks to everyone for reading along.
  4. z1ulike
    I've always wondered which is "the best camp stove money can buy." Now I know it's an AGM WCS3. And a very well presented one I might add. Thanks for going to the effort.
  5. Ed Winskill
    Great presentation.
  6. JP2
    JP2 Subscriber
    Canada
    Very nice plus I have learned a lot because I don't know much about those one.
    Thank
  7. Marc
    Marc Subscriber
    Oregon, USA
    Thanks gents, appreciate the kind comments.
  8. shagratork
    Any idea of the date of this stove?
  9. Marc
    Marc Subscriber
    Oregon, USA
    Terry Marsh's site lists an AGM model LCS-42, which looks to be a copy of this stove in a different color, and dates that model to the late 50's.
    Edit: The cardboard box styling and sticker make me want to put this stove later than that, into the 60's or even 70's, but I have no documentation for that and am likely wrong.
  10. ROBBO55
    A good detailed post @Marc :clap:
  11. Marc
    Marc Subscriber
    Oregon, USA
    @ROBBO55 Thank you!
    During the first test of this stove, it had the occasional orange tinge to the flame, so while I was busy in the shop doing various things(I was...ahem.....tidying up...) yesterday evening, I fired it up and gave it a "bloody good gallop" as James Herriot might have said. Burn the last few remnants of the old stale fuel out of the system.
    Today I refueled it with a substantial amount of fresh white gas, and took the opportunity of having a running stove to try "canned dog", a delicacy I've seen reported here on the forum.
    Once the stove was up on stride, it burned without the occasional orange tinge of before.
    Not bad. Should have used the other burner for potatoes.
