Air restrictor converting silent kero burner to benzine
Discussion in 'Stove Forum' started by gideon, Aug 12, 2019.
  1. gideon
    Here is a drawing of a restrictor that i've made today for my Optimus-535 and Radius-10 to convert this stoves to run it on benzine. Matherial is brass or stainless steel. No needs to change the jets.
    I am brewing clean benzine (white gas) from regular automobile 92nd by destillation, 60-120 Celsium degs boiling (there was a thread earlier). And it is a twice cheaper.
  2. ArchMc
    ArchMc Subscriber
    Mojave Desert, California
    Be careful. Boiling gasoline is a risky endeavor.
    ....Arch
  3. Staffan Rönn
    Staffan Rönn Subscriber
    Stockholm, Sweden
    Hmmm…. brewing benzine…. is that what they normally call Moonshine? :-k
  4. kerophile
    kerophile United Kingdom Subscriber SotM Winner
  5. Staffan Rönn
    Stockholm, Sweden
    I guess we are all sinners, one way or the other… But setting sins aside, I would really think twice before brewing gasoline. Not only because of the flammability, but even more because of all the carcinogen
    aromatic additives. Modern car gasoline is very aggressive.​
  6. OMC
    OMC Subscriber
    I knew Gideon side comment re boldly brewing his own white gas from auto gasoline sounded familiar, link. I'm not a fan of the process but I digress.
    Re OP: restrictor to convert (No.5 size) silent burner kero to white gas.
    if I interpret above drawing correctly Gideon shows us a 34 x 13mm restrictor tube w/flange.
    No holes in the side?
    This is not unlike 1980s Optimus Hiker / 111T Triple fuel, regulated silent, comes with
    a kero jet installed and two 33 x 13mm restrictor tubes w/ side holes (*2 & 3), *one tube w/flange.
    a restrictor tube for white gas
    a restrictor tube for alcohol (alcohol jet as spare)
    an SRV filler cap
    source
    thx all omc
    @gideon
  7. gideon
    @OMC , yes, there is no holes in my restrictors but tube is 1 mm shorter than 111th's. I have one 111 hiker 3-fueled and 2 restrictors there for benzine and meth but i thought to make it myself and now it works. Hope pics coming soon.
  8. David B.
    An island in the Salish Sea
    Petrochemical refineries have a habit of blowing up and killing workers. And those are subject to safety regulations, designed by professional engineers, and operated by trained workers. No way can I consider a DIY mini-refinery (with none of the safety measures a permitted plant has) to be a safe idea, particularly if one does it inside one's home!
  9. Marc
    Marc Subscriber
    Oregon, USA
    Imagine living in an apartment with your next door neighbor doing that.
  10. snwcmpr
    snwcmpr Subscriber
    I am trying to understand the reason.
    Is kerosene not available where you are?
  11. David B.
    He's refining white gas, not kerosene. Everything I've heard indicates white gas is usually hard to find outside of North America and Australia, but I still wouldn't want to have anything to do with refining my own, even if I lived in Europe. Just too risky.
  12. snwcmpr
    snwcmpr Subscriber
    Exactly.
    Why would he need to modify a stove that uses a fuel that he needs to refine in order to use the (modified) stove.
    Why not use kerosene.
  13. Simes
    Simes Subscriber
    Not wanting to be poisoned by the additives by burning pump gas may be a sensible precaution.
    A suitable risk/benefit analysis may be worthwhile in this instance.
    Also taking into account mortality rates amongst home distillers, either from failure of the still itself or consuming the product.
    'Just because', may also be a reasonable argument.
  14. snwcmpr
    snwcmpr Subscriber
    @gideon Any updates?
    Can you find kerosene in your area?
