Aladdin M 1942
Discussion in 'Stove Forum' started by Yannick Michel, Aug 3, 2022.
  1. Yannick Michel France
    France
    Hello
    I found a nice Aladdin M 1942 US military stove and I have some question.
    I fired it and it was working correcty, I think.
    Then I tried to dismantle the pump to see the srv at the bottom of the pump. The pipe washer was new.
    I tried it again but the pump was hard to pump. Is it normal to have white gas inside the pump ??
    Sorry for my English.
    Yannick
    650C38FE-524A-47C7-8774-8E5CAC3BF478.jpeg 5148EB62-EAF8-4047-9541-295773F72E96.jpeg
  2. Yannick Michel France
    France
    Après avoir pompé 20 fois, voici à quoi ressemble la pompe ! And there is white gas in the pump.
  3. Ian
    Ian Subscriber
    West Yorkshire
    There should not be fuel in the pump. Unscrew the large knurled nut (red arrow} and you can remove the complete pump unit. The NRV is accessible by a hex nut on the bottom of the pump tube. If you unscrew the pump handle {green arrow} from the plunger there may be a spare pip inside. There may be other spares too. Better to make and fit a new pip.
  4. Yannick Michel France
    France
    @Ian Thank you for your reply. I checked the pip and it was fine.
  5. Yannick Michel France
    France
    The first time I fired it, as you can see on the photo the stove worked fine. Then I checked the NRV which was fine and rebuild the pump… And now the pump seems not to work correctly ( fuel inside and pressure in the tube). What is the problem ?
  6. cottage hill bill
    cottage hill bill SotM Winner Subscriber
    The pip is not fine. You get fuel in the pump because the NRV is leaking (unless there is a hole in the pump tube). Unless a previous owner has recently replaced it the pip will be rock hard (so will the spare ones inside the pump). Take the NRV apart and press on the pip with a wooden toothpick. The pip should have some softness to it. Order a new one from The Fettlebox or make one.
  7. Yannick Michel France
    France
    Ok I will check again.
    But is there a possibility of leakage here (red arrow) ?
  8. Ian
    Ian Subscriber
    West Yorkshire
    Is the NRV operating correctly? With plunger removed you can test it with a long pin; you should be able to feel the spring compressing & relaxing.
  9. Yannick Michel France
    France
    In which side should I test it with a long pin Ian ?
  10. Ian
    Ian Subscriber
    West Yorkshire
    From the top, down the middle of the pump tube, so it goes through the hole at the bottom
  11. Majicwrench
    Majicwrench Subscriber
    In your post #7, it does not need to make a seal at your red arrow.
  12. Yannick Michel France
    France
  13. Yannick Michel France
    France
  14. Yannick Michel France
    France
    @Ian the spring is compressing abd relaxing nicely.
  15. Yannick Michel France
    France
    My God ! I found my mistake. After watching a nice video, I understood that I put the spring and the pip in a bad position !! It is why I had fuel in my pump !!
  16. Ian
    Ian Subscriber
    West Yorkshire
    If the pip & spring had been in their correct positions, you would not have been able to compress the spring as in your previous picture.
  17. Yannick Michel France
    France
    You are right @Ian
  18. Majicwrench
    I love figuring out my stupid mistake, which I do often.
    Good job.
  19. Yannick Michel France
    France
    @Majicwrench ahahah sure ! A such mistake changes everything !
  20. Yannick Michel France
    France
    I tried now it is working, to boil water. 7 minutes to boil half a liter. It is not the fastest stove I have. What is the correct time for an Aladdin ?
    Thank you.
