Alcohol Powered Eta-Power
Discussion in 'Stove Forum' started by HunterStovie, Mar 14, 2019.
  1. HunterStovie
    Parker, Colorado, USA
    Not sure if this has been done before, or if anyone cares, but I thought this a most useful addition.
    1 slightly used Primus Eta-Power minus the stove, but it did come with a 1.7 liter pot and frypan lid.
    Here is the stove with its piezo in place, if you have the Multi-Fuel version you don't have one.
    Now drop in one alcohol burner, in this case one from Esbit.
    Here it is on simmer, and a side view to show clearance above the burner
    Here is a 1 liter eta pot with 500ml of water. It looks like very even heat distribution.
    8 minutes later we have a rolling boil. Next step will be a cooking test.
    Hope you enjoy,
    Mike
  2. snwcmpr
    snwcmpr Subscriber
    Here, not There
  3. anlrolfe
    anlrolfe Subscriber
    Louisville Kentucky, USA
    Proof that being more efficiency doesn't have to be faster. I'd like to see some Trangia pots designed with increased surface area, wrinkled, grooved or incorporating heat exchanger style.
  4. snwcmpr
    snwcmpr Subscriber
    Here, not There
    Would not 'more efficient' prove it self to be faster? If not, it is not more efficient.
    I know the point is not to be faster, but to use less fuel, thus more efficient of the fuel.
  5. anlrolfe
    anlrolfe Subscriber
    Calories burned vs BTU absorbed into the pot are two totally differant things. If we were burning the same cal/min and raised the temp better in one system than another than yes but alcohol to butane or gasoline vs Kero and burner X vs Y are apples to orange BTU wise. These days I'm in no hurry, I'll just go low and slow.
  6. HunterStovie
    The factory Eta burner was not conducive to cooking with wide pots because the small burner created a hot spot right in the middle.
    I 'm more into cooking than boiling water unless I'm making tea, coffee, or rehydrating a meal.
    The alcohol burner allows cooking while doing the other things quietly.
    I was not looking for efficiency, just lucky happenstance that the burner fit and now has a new home.
    I'm also adding a Trangia burner to my other 2 Eta-Power MF stoves
    Mike
  7. Punisher
    Punisher Subscriber
    I did this setup myself and works excellent.
  8. HunterStovie
    After 15 years I finally used an alcohol burner and just bought my first brassie, a new Optimus Svea.
  9. snwcmpr
    snwcmpr Subscriber
    Here, not There
    Uh Oh. You are a lost cause now. Next will be an '00', a '210'. a '21', a '45'.....
  10. HunterStovie
    Not if I use all my money on an Optimus 9 !! Just kidding.
  11. snwcmpr
    snwcmpr Subscriber
    Here, not There
