Another flat pack burner bell
Discussion in 'Fettlers Master Class' started by Twoberth, Mar 8, 2021.
  1. Twoberth
    England
    I have an old (x for 1933) Primus 96 that had no burner bell.
    Using the template and techniques mentioned here I cut out the 2D shape in brass sheet,
    but this time I used a mandrel to create the correct 3D curvature.
    Then brazed the sides, cut the slots
    and flared the top
    Then I cut and brazed the tapered collar onto the bottom of the bell.
    Cleaned it up and fitted it to the lipstick
    fitted the original burner plate
    and fired it up
    The tapered collar is a good fit on the lipstick and the stove runs well and maintains vaporisation. Another old 96 back in working order.
  2. kerophile
    Hi @Twoberth Truly the IKEA of the stove World!
  3. Twoberth
    England
    @kerophile
    Thanks, and unlike IKEA projects I had no bits left over!
  4. IvanN
    N.E. Oregon
    That’s excellent! The bell seems to be the hardest part to source.
  5. Ian
    Ian Subscriber
    West Yorkshire
    Tidy! :)
  6. z1ulike
    Outstanding workmanship! I'm really impressed.
  7. ROBBO55
    It's working nicely :thumbup:
  8. presscall
    @Twoberth Great stuff Duncan. Presumably you’d a fair amount of annealing to do during the metal-bashing?
  9. Twoberth
    England
    @presscall
    Thanks John. Several anneals with the brazing torch.
  10. hikerduane
    Never seen that, I just buy another stove and rob the parts. Nice work.
  11. Twoberth
    England
    Thanks everyone.
  12. Twoberth
    England
    Before and after
  13. Optimust
    @Twoberth
    Thank you for another flat pack burner bell design. I used your original design to
    bring my Radius 42 back into use. I had to
    Silver solder a thin check nut on the base to suit the burner. It works a treat, & Thank you again. My Best Regards. Optimust. O:)
  14. igh371
    Durham
  15. Twoberth
    England
    @Optimust
    Good work on your Radius 42, and thanks for your comments.
    I am currently making a bell and flame plate for an old Monitor !7B, and will post photos in the Stove forum when finished
  16. Twoberth
    England
    Latest template with parallel sides. Saves a lot of snipping and filing.
