Another MSR stove
Discussion in 'Stove Forum' started by 8R Pete, Apr 6, 2020.
  1. 8R Pete
    8R Pete United States Subscriber
    New Jersey
    I saw an MSR DF stove on E -bay with a buy it now price and bought it. Pics to follow.
  2. Harder D. Soerensen
    Denmark
    Never pass a good temptation - You might not get it again ;-)
  3. MrAlexxx
    MrAlexxx Subscriber
    Spoken like a true STOVIE!!! lol :)
    Alex
  4. 8R Pete
    New Jersey
    Here it is. Curious as to how it burns kero?
      File size:
      111 KB
      53
  5. presscall
    @8R Pete
    I thought you’d said it was a DF (Dragonfly). That’s an early X-GK. Swap gasolene G jet for a K kerosine and you’re in business.
  6. Hazet
    WNC USA
    Nice stove Pete. How does it work on kero?
    More pics, courtesy of the seller.
    IMG_1628.JPG IMG_1629.JPG IMG_1630.JPG IMG_1631.JPG IMG_1632.JPG IMG_1633.JPG IMG_1634.JPG IMG_1635.JPG IMG_1636.JPG IMG_1637.JPG
  7. 8R Pete
    New Jersey
    I didn't try it yet on Kero. Will try today. Thanks Hazet for the photos!
  8. presscall
    Ah, I see @8R Pete, you meant a Duel-Fuel and not a Dragonfly. Ignore I ever posted - evidently you have! LOL
  9. 8R Pete
    New Jersey
    Presscall-I posted the 1 pic and went to sleep. I woke up and saw the posts this morning. All good-I appreciate all comments. You got me curious- was there an earlier dragonfly? I bought the stove on E Bay from a member here-Hazet so I knew I was in good company! It didn't come with any spare parts.
  10. presscall
    I’ve one that’s early but not the earliest.
    Here’s a possible prototype
  11. 8R Pete
    New Jersey
    Wow what a difference in the body. I have a Dragonfly but have more holes in the body-bought it maybe 10 years ago. I had one I bought in the 90's but sold it when times got tough.
  12. 8R Pete
    New Jersey
    Here is the stove on Kero. I preheated it with alcohol 2 times but it didn't want to light. I took my propane torch to heat up the coil and after a huge flame that scared me with its size, it finally caught.
      File size:
      85 KB
      20
  13. 8R Pete
    New Jersey
    I actually like the white gas in this over kero. The jet that is in there has no marking on it. What other MSR jets will fit? Did the stove come original with a kero jet?
  14. Lennart F Sweden
    Vänersborg, Sweden
    The usual for MSR GK or international/universal versions is that they are delivered with one jet each for the designed fuels.
    It may be possible to burn everything with one jet as I have confirmed on Primus Omnifuel.
  15. snwcmpr
    snwcmpr Subscriber
    A few years ago Cascade Designs sent me a "K" jet from old stock. I called them, they found one, they sent it to me.
  16. Hazet
    WNC USA
    Take the jet out and look inside it. If I remember correctly, it's the type that has the built in screen. There's also no sintered brass(?) filter. It's got a short threaded rod in the passage (falls out, you don't need to unscrew it), but I can't recall if that one has the hole through the center of it or not.
    I don't recall if the thread pitch/diameter/installed height of the jet is the same as a later gk/x-gk/etc jets.
    I also never tried to run it on kero, so I can't speak to results on that type of fuel.
  17. 8R Pete
    New Jersey
    It runs fine on white gas better than Kero in my opinion. I did remove the jet to see if there was a marking on it, but there was not. I have an Optimus 111 T that I use kero in it. I have several MSR jets so I can see if something with the K stamped on it matches. Not really a big deal. Really nice running stove.
