BAT Stove from German Democratic Republic *
Discussion in 'Bat' started by kerophile, Jan 20, 2008.
  1. kerophile
    Hi, here are some photos of one of my BAT stoves. This particular one is a 2-pint paraffin stove with a brass tank and is collapsible. It is fitted with a roarer burner;
    You will see that there is no lettering on the sides of the fuel tank, nor on the burner.
    Look at the spacing of this lettering....do you think there is space to put in the word "East" in front of Germany?
    The quality of the engraving on this stove is good.
    Here is a close-up of the "BAT" logo of this manufacturer.
    The observant among you will have already noted that I do not have the reserve cap, which is normally parked on the filler cap, when not in use.
    You will see that this stove is well-made, with good engraving and fittings, and the soldering is neat.
    Kerophile
  2. alnl1996
    Ontario, Canada
    Very nice looking stove Kerophile. Has it ever been lit and when was it made?
    Take care.
  3. kerophile
    Hi alnl, Yes, the stove has certainly been operating as I always fettle my stoves before I make them pretty. I renewed all the seals and washers on this stove and would have used citric acid to remove carbon and tarnish from the tank and burner.
    I acquired this particular model from the Netherlands. I believe the stove dates from the 1960s/early 1970s perhaps. It would probably have been made near Leipzig, in what was then East Germany (This was before German re-unification).
    Kerophile
  4. sgt_hicks
    Nice :-) I also had one, it was brand new till I've lit it. It works but it misses some parts [ring around the burner and all legs...]. The flame is a bit uneven but roars as it should :-)
    Year of production unknown.
