British Army No. 2 Cooker
Discussion in 'Fettling Forum' started by Scout89, Feb 24, 2021.
  1. Scout89
    Scout89 Subscriber
    Knoxville TN
    Howdy y'all,
    Tennessee here needing a few parts and advice,
    I have a No. 2 Cooker dated 1992 in very decent shape. It is missing the legs! Can anyone help me find spare parts for this stove. Also, the cap that covers the burner will not unscrew. I have doused it with penetrating oil to loosen it up. Any protips on getting it unscrew?
    Best regards,
    Garry
  2. presscall
    @Scout89 Howdy, Garry.
    Sounds like your referring to a No.2 (Modified) which has a silent burner (with a cap) and not the No.2, which has a roarer burner (with a flame plate).
    One of these.
    The legs, which serve also as clamps for the lid when the stove’s stowed, are unavailable as spares from any source I know of in the UK and a worse example of the stove than you’re fixing up would need to be found as a donor.
    The cap, as you’ve discovered, is a pain to remove. It doesn’t screw on, or off, but is an interference fit on the burner head. The tool you see in the lid of the stove ...
    ... has a pry-bar end and that’s meant to be used to work around the cap, bit by bit and gently, here ...
    ... to prise the cap off. Two or many more (it’s variable) circuits of the cap circumference should see it release its grip and pop off.
    Regarding the legs/lid clamps, I’d to make a couple, otherwise unobtainable, for THIS prototype No.12 stove so fabricating a pair from steel strip and painting them olive drab is another option.
  3. Scout89
    Scout89 Subscriber
    Knoxville TN
    This is great John I had thought of trying to get a pair put together! Do you have measurements or know where I can get them???
  4. presscall
    @Scout89 Gladly, I’ll post photos and measurements here. Give me a couple of days.
    A question for you Garry. What’s the furry little chap you’re sharing the photo with in your avatar?
  5. Scout89
    Scout89 Subscriber
    Knoxville TN
    Didelphidiae Virginiana, the American Opossum only native marsupial to North America. I have a friend who somehow finds the babies, raises them, and then returns them to the wild. That's a real live baby Possum, as we call them. The "O" is silent. They are a neat little critter.
    Thank you for your time and willingness to help! It is greatly appreciated.
  6. presscall
    @Scout89 I think I’ve got every dimension you need here.
    1884D938-1C4B-4DE2-B5C1-3C433DD75FA8.jpeg 3F2745EF-3483-40F1-81B7-FE6C3D8B27B7.jpeg 3C77FC79-6446-4787-B9EF-6433FCA26BDE.jpeg 7E7040AB-E01A-481A-9600-A5067B8CE183.jpeg A8B2F49E-68CA-444B-BB73-DED8DBB8964C.jpeg E3F0F5F1-907C-481B-9B4F-58AAB8EC0DC2.jpeg 3B68FB22-A528-4DF4-A1F5-3A2C9E6F5EE6.jpeg
    Here’s the tool for prising the cap off.
    The legs/clamp pivots are simply sprung into place.
  7. frg7700
    frg7700 Subscriber
    Probably teaching granny to suck eggs but a quick circuit or two of the cap with a blowtorch before trying to prise it off will make the job a lot easier.
  8. Scout89
    Scout89 Subscriber
    Knoxville TN
    John!
    These photos are really great! I used the tool and the cap came right off. I hope to find someone to machine the legs for me sometime in the near future. I greatly appreciate the help. I will get some pics up of my stove the next sunny day.
    Garry
  9. cottage hill bill
    cottage hill bill Subscriber
    @Scout89 You should be able to buy some flat bar stock at a local hardware. The big box stores and Tractor Supply carry it. If you have a bench vise you'll be able to bend a set of legs. Drill a couple holes in each end and solder a bolt in place for the pins. No need for a machinist for this part. The legs don't have to be an exact match in thickness or width for this application.
    Best of luck.
  10. Scout89
    Scout89 Subscriber
    Knoxville TN
    Here's my No. 2, pretty much complete. Minus the legs of course. Looking forward to cleaning it up.
  11. Scout89
    Scout89 Subscriber
    Knoxville TN
    Finally get a move on getting this put together. What is the thickness of the bracket?
  12. shueilung.2008
    shueilung.2008 Subscriber
    Uruguay
    @Scout89
    They spread down here too...
    Enrique
  13. presscall
    Eighth-of-an inch or 3mm Garry.
