British no:2 missing leg
Discussion in 'Stove Forum' started by Finncooker, Jul 5, 2020.
  1. Finncooker Finland
    Finland
    Hello you all!
    I just acquired a British no:2 field stove in reasonable shape other than a one missing leg / stand. The front leg is there but the one in the back is gone. Any ideas where one might get it? As i understand these are fairly uncommon here in Finland so i am putting my hopes on you guys! Any suggestions are highly appreciated!
    Yours: Max
  2. Surveyor
    Fife
    Both are the same on mine so you might be able to use the one you have as a template
  3. Finncooker Finland
    Finland
    Yes, that came into my mind also, but i still would like to have one as i am planning a full restoration on it. I kinda like this machine..
  4. Finncooker Finland
    Finland
  5. Finncooker Finland
    Finland
    Thre she is! Not sure about the colour though...
  6. Surveyor
    Fife
    Mine where the paint removed i think is deep bronze green
  7. Finncooker Finland
    Finland
    Yep! Mine is way too GREEN :lol:
  8. Surveyor
    Fife
    This is the No 2 Stove i bought and it arrived on Friday, the original colour can be seen on the tank then latter painted Matt Green, It looks a state and i am waiting for washers to arrive to start, the pump does not pressure the tank.
    The label on the lid appears to be a stick on one and at some point was painted over
  9. presscall
    I’ve not seen a source in the UK. I needed one for one of my Turley & Williams stoves (similar arrangement) and had to make it from mild steel strip.
    It was a tougher job bending the stainless steel strip for this military No.12 prototype that was missing them.
  10. Finncooker Finland
    Finland
    Nice! Mine has no manufacturer stamp on it. Made by who and when :shock: ? Only who knows.. i kinda have a feeling that it is quite old, maybe WW2- issue.
  11. Finncooker Finland
    Finland
    Job well done!! I might have to do the same thing...
  12. presscall
    Often a company called Surmet. But T&W also I believe. Not always badged up it’s true.
  13. Finncooker Finland
    Finland
    Cool model that stainless 12!!
  14. Finncooker Finland
    Finland
    No badge, sadly so. Would have been interesting to know.
  15. Surveyor
    Fife
    This is the other No 2 Stove manufacturers lab IMG_20200625_190432.jpg le
  16. Finncooker Finland
    Finland
    One rumor goes that these were part of the gear of the Centurion- tanks that were imported to Sweden and from there it somehow found its way to neighbouring Finland.
  17. kerophile
  18. Finncooker Finland
    Finland
    Thanks man! That might just be the story behind my cooker. Exactly the same model with the red warning sign on top of the instructions!!
  19. Surveyor
    Fife
    Just had another look at your pictures is the internal base colour different from the exterior, if so that may be the original paint
  20. Finncooker Finland
    Finland
    No, it appears to be the same. No sign of the original paintwork unless it is as it is
