BRS 8A by APG
Discussion in 'China' started by gieorgijewski, Sep 15, 2019.
  1. gieorgijewski
    gieorgijewski Subscriber
    As "We know" under that name was a few similar constructions with differencies.
    two type of pumps (older and newer)
    a few bottles
    two burners
    two wrenches
    APG versions - is cheapest now
    in set:
    biggest bottle
    pour wrench
    good burner
    small windshield
    work:
    my example is "near new" - works two weeks in Georgia at 4000 m. on autofuel.
    My test's: - nipple seems to be little too big on autofuel, stove needs circa 10 minutes to constant blue flame
    on gas - working perfect
    I am not sure is it good idea to storage/transport pump in bottle with fuel
    but i've seen only 1 example of pump transport box...?
    It its good idea - after work on liquid - burn on gas to clean generator.
    DSCF9096.JPG DSCF9081.JPG DSCF9082.JPG DSCF9083.JPG DSCF9084.JPG DSCF9085.JPG DSCF9086.JPG DSCF9087.JPG DSCF9088.JPG DSCF9090.JPG DSCF9091.JPG DSCF9093.JPG DSCF9094.JPG DSCF9095.JPG
  2. Simes
    Simes Subscriber
    The short squat tank is interesting.
    I do like.the 8A, just wish I hadn't tried kero in it to be honest, only because it's damn difficult to get the silly pricker anywhere near the nipple. Grrr
  3. gieorgijewski
    i think - this box but with screwed wet part covering will be useful...
  4. gieorgijewski
    transport box for pump, wrench and spare parts...
  5. ROBBO55
    Thanks @gieorgijewski for your comments on this stove.
    Nice idea to have the pump in a transport box. :thumbup:
  6. Simes
    Simes Subscriber
    Yes a neat addition.
  7. gieorgijewski
    A few questions for 8a owners:
    Did We know nipple diameters?
    4,5 kW power - IMO on kerosene - on autofuel?
    APG instruction is enigmatic - in other versions is anu technical data?
  8. Simes
    Simes Subscriber
    @gieorgijewski Just a quick comment as I'll not get an opportunity to look at mine in detail for a week or so.
    After the rather failed kerosene test and the nipple as supplied leaking I managed to shear it off so had to order spares, they are cheap and available in a variety of sizes, and I'm unsure what size I have currently fitted.
    My plan is to modify the pre heat tube arrangement at some point to give better thermal conductivity for kerosene. Something a bit more engineered than wrapping copper wire around. As a gas and naphtha burner they work well, I suppose a burn through with gas on mine should clear some of the carbon out, but it's getting the damn pricker near the jet when working is the PITA. :rage:
  9. gieorgijewski
    add power
    add power
  10. gieorgijewski
    time to boiling test
    15 celsius
    no wind
    water circa 6
  11. cmb56
    cmb56 Sweden Subscriber
    Norrköping, Sweden
    The nipples/jets available for the BRS 8/8A and 12/12A are these:
    #30 for Kerosene?
    #33 for Gasoline/Kerosene?
    #35 for Gasoline?
    I have not been able to measure the apertures on them and the question marks are because of what my guess is.
    Michael
  12. gieorgijewski
    thanks
    ok ... it is possible to be done
    but pre heat tube mounting in that burner is not acceptable as "multifuel" function
    original wrench is "for nothing" in "change nipple" task
    moore - to dismounting "You" need special wrench
    but - mounting - even with that tool was very difficult
    pre heat tube shape/design - makes this burner "one nipple" - "as is"
    if tube was 10/14 mm longer with "any angle in burner center" it will be as is declared in instruction.
  13. Simes
    Simes Subscriber
    Agree completely with everything there @gieorgijewski.
    Brass tube is available online, and a car brake pipe bender might get the tube geometry to stay within the flame for longer, rather than just at 2 points as it is at the moment.
