C1U2 Chinese Copy of 533 Stove.
Discussion in 'China' started by HappyCamper7, Jul 22, 2019.
  1. HappyCamper7 United States
    California
    Bought this on ebay and used it on two camping trips. Likes to spill fuel after turning valve off onto the font. No pressure safety valve on this one. See photos. Base screw was stripped and loose from factory making pots almost fall over. Also, metal top peeled off a layer of paint on first few burns and it does not have a cleaning rod in the generator. Lastly, it appears to be missing the bottom burner ring. It burns very hot however, but this thing scares me. Can anyone spot any other differences?
  2. pyro_P Australia
    Westraya
    IMO, replace that with a Coleman 533, thank me later.
  3. Simes
    Simes Subscriber
    It worked twice, that has to be a result of sorts. :)
    I've still to throw a match at the BRS 12.
  4. Harder D. Soerensen
    Denmark
    @HappyCamper7
    Listen to to your inner gut feeling. If you don’t trust it - don’t use it (or at least only use it, while under adult supervision... having a PLAN B in case it goes sour).
  5. HappyCamper7 United States
    California
    I have a new old stock 502 that I love, it just doesnt have the BTU output that this thing has. Ever since I rebuilt it, it has been running better without flareups at the beginning and after shutdown (still a ticking time bomb). I really wanted to put this up here to warn people against buying it. Spend the extra 10 bucks and save a trip to the emergency room.
  6. Marc
    Marc Subscriber
    Oregon, USA
    Find a 400. Boatloads of heat while simmering nicely. Common on CL/Offerup/Ebay.
  7. itchy
    @HappyCamper7
    Thanks for the write up, pictures and your thoughts.
    I, for one, find the Chinese quasi-copies of Coleman (and other western) designs curious and interesting is a twisted-cynical way. Outward appearances are often similar and suggestive but certainly not exact copies. Inner workings are functional, without superfluous quality, and with no effort to include safety features that might cut into profit. A business model that is not unique to China and works well in our global use-and-dispose economy. And, almost impossible to avoid at this point.
  8. pau-i-amor
    pau-i-amor Subscriber
    I read your notice too late :doh:I thought my english was bad until I read the instructions!:D
    This is my Coleman 533 clon: The LSO´618 stove. Boiling eggs test:
    In fact, it seems more powerfull than Coleman 533.
    At least the flames exceed the pot (a medium size pot!).
    Face to face Chinese LSO-618 vs. Coleman 533
    There is no clip for hold the control valve knob when you turn the light off.
    There is no wire neither needle inside the gasifier.
    There is no pressure safety valve.
    Pot stands aren't zinc plated. Maybe only painted.
  9. presscall
    presscall United Kingdom SotM Winner Subscriber
    Well said. Not only is there nothing reported to recommend it, there’s a lot about it to steer well clear of.
