Cadac camping unit
Discussion in 'South Africa' started by Andrew, Mar 2, 2018.
  1. Andrew
    Port Elizabeth South Africa
    Hi everyone.
    I got this “look and cook” Cadac camping unit to use with my oven . Unfortunately it did not come with a hose, lamp and connections. I was unable to find any connection for it so had to modify it to use a modern Cadac connection. I’ll keep the original parts in case I find the unlikely missing parts.
    The age of the stove must be between the two that were posted recently as the knobs are the same as the first and the suitcase handle the same as the second. The blue colour is original and the black in the base of the case looks original too.
    It will need a good cleanup and repaint.
  2. presscall
    @Andrew
    A classic ‘gassie’, which isn’t everyone’s cup of tea but one I definitely appreciate.
    Who’s the manufacturer of the oven? Made in the USA evidently.
    From the instructions ...
    (cooking grid). Great sounding word.
    You and the instructions refer to a ‘lamp’ Andrew, but I’m not familiar with the word in a stove context. I should be able to work out what it is, but can’t.
  3. Andrew
    Hi John. @presscall
    The oven does not have a makers name on it . The stove had a two way connection with a control to regulate the gas flow for gas lamp for light or for another gas appliance. Unfortunately I have no idea what the connection looks like.
    Andrew
  4. kerophile
    Hi John @presscall and @Andrew . Interesting to read your reference to
    Kokerroster.
    I have a Heinze Geniol NATO cooker as issued to Dutch army. There is a reference on the instruction plate to : KOOKSTOEL. I got a translation of “Cooking seat” from the Internet but didn’t know what this actually meant. I would like to have your advice:
  5. Tony Press
    @kerophile
    Would it be the trivet/pot rest?
  6. kerophile
    Oops! My mistake.
    On closer examination the word used on the Dutch Heinze Geniol is “ KOOKTOESTEL”
    Which tanslates simply as “Cooker” I understand.
  7. presscall
    Ah, I see. Literally a ‘lamp’. Clever. Brilliant of the designer to recognise the need to light up what’s cooking.
    Biolite came up with a more everyday(night) use for the USB socket than for charging a phone.
  8. MrAlexxx
    MrAlexxx Subscriber
    Cool looking old gassie that's for sure. I thought the oven might be like one I picked up but slightly different. Maybe same manufacturer though? Says MILCOR embossed into the back. Now I have to bake some cookies next week. Thanks... :)
  9. Andrew
    @kerophile ”kooktoestel” would translate to “cooking set” or more likely “cooking appliance”
  10. kerophile
    Hi @Andrew and John @presscall . thank you for sorting that out. I will ask a Moderator to correct my original post.
  11. Andrew
    @presscall
    Hi
    I found the proverbial hens tooth yesterday.
    I was at a secondhand shop and saw the connections and hose for the stove. Luckily I still had the original female stove connection which I refitted to it.
    The shop owner said that it had belonged to his father and that he remembered using it with a stove in Rhodesia when he was a child but could not remember what the stove looked like.
    The valve on the connection only controls the gas to the lamp which means the stove can be used without the lamp.
    The lamp is probably from the same era as the stove but I am not certain of this.
  12. Simes
    Simes Subscriber
    Is it just me or does that look like a street lamp. :-k
    Great you found the bits that were missing.
    Did you discover who made the oven? The temp. gauge is the only bit with some sort of provenance.
  13. presscall
    @Andrew
    Beautiful! A Petzl head lamp would do the job of cooking after dark as well I suppose but nowhere near so stylishly. Thanks for posting.
  14. Andrew
    @Simes
    Unfortunately I have no new information on the oven.
  15. Andrew
    Hi
    I found another one of these stoves today this time with the original hose and connection.
    The only difference is the lighter blue on the outside of the case, the cream colour on the inside, the clip holder on the inside which was corroded off the other stove and the slight difference in the print and wording of the instructions.
    It’s in a better condition than the first one.
    Andrew
  16. Braam South Africa
    Centurion
    Hi Andrew
    Would you consider selling?
    Braam
    0836314344
  17. Andrew
    Hi @Braam
    Welcome
    Do you collect stoves or looking for one to use.
    Unfortunately the stoves are not for sale but I will let you know if I find another one and decide to sell it.
    Andrew
  18. It'l Dodat
    Hi all.... OK So I'm a Johannesburg boy & I've got , and I've just picked up on this.... Actually I might even have 4....
    One comes with me all the way from Rudu in 1974,
    One is a brand new, 100 % complete with all it's spares and the lot (see pic)
    But the third may be of interest... I've stripped it to turn it into a suitcase braai & for spares and got the whole supply / burner ETC.
    stove gas 2 burner new a.jpg stove gas 2 burner new b.jpg stove gas 2 burner new d.jpg stove gas 2 burner new e.jpg stove gas 2 burner new f.jpg stove gas 2 burner new g.jpg 20180212_121936.jpg 20180212_122008.jpg 20180212_122018.jpg 20180212_122055.jpg 20180212_122101.jpg 20180212_122109.jpg Bloem 04-2016 spagbol comming up yummie.jpg
