Campus No.5
Discussion in 'Campus No:5' started by Robert Radcliffe, Oct 13, 2020.
  1. Robert Radcliffe
    Stockport UK
    A very strong burner once warmed up although it seems prone to blowing itself out. Nonetheless a lovely stove. It appears to have had a new control spindle and packing nut. As I read in a previous post the SRV built in the tank is clearly not intended for user servicing but appears to be working fine at the moment.
    I'm undecided as to whether I should do a restoration on the case with this one.
    Any help with dating would be appreciated.
    20201013_110538.jpg 20201013_110544.jpg 20201013_110548.jpg 20201013_110606.jpg 20201013_110639.jpg 20201013_110655.jpg 20201013_110715.jpg 20201013_110957.jpg 20201013_111201.jpg 20201013_113522.jpg 20201013_113337.jpg 20201013_113435.jpg 20201013_113321.jpg 20201013_113231.jpg 20201013_113612.jpg
  2. Tony Press
  3. Robert Radcliffe
    Stockport UK
    Well decision made - I couldn't live with the case in the condition I received it so a few hours later I'm at this point. Paint stripped and lid polished. I'm thinking a clear lacquer on the lid and a dark paint for the lower half.
    20201015_152306.jpg 20201015_152322.jpg 20201015_152346.jpg 20201015_152404.jpg
  4. hikerduane
    That should be a 5B with the SRV and lack of a pump. Metal looks good, but I'd paint it black.
  5. Robert Radcliffe
    Stockport UK
    @hikerduane yes a 5B, I think all black was probably the original condition. The top had clearly had a poor paint job, the bottom was black. It would look good in black for sure.
  6. nmp
    @Robert Radcliffe
    The green on the top of the case may well have been the original colour and the black the paint job?
    Mine is in the green all over and as you say it’s a bit tatty due to thin paint probably
    These are great stoves and noisy!
    Take a look (no doubt you have!j
    Campus 5b
  7. Robert Radcliffe
    Stockport UK
    @nmp looks like you're correct about the paint then. I may have to go two tone!
  8. Robert Radcliffe
    Stockport UK
    Well I know a few members would have preferred to see original colours but I went with the clear lacquer on the lid. I used a high temperature ceramic and silica paint on the pot holder, once cured meant to be good to over a 1000°C. Here's the end result.
    20201019_113619.jpg 20201019_113627.jpg 20201019_113650.jpg 20201019_113748.jpg 20201019_113802.jpg 20201019_113829.jpg
  9. Ian
    Ian Subscriber
    West Yorkshire
    Nice work, Rob. :)
  10. Robert Radcliffe
    Stockport UK
    Thanks Ian!
