Champion ?
Discussion in 'Mystery Stoves' started by Admin, Dec 21, 2010.
  1. Admin
    Admin Courtesy of Iani
    This arrived this morning, perhaps now we are a bit further forward with the maker and the decal?
    The outer ring of the decal is black, inner ring gold, top and bottom inner decal part is red. The band across the centre is gold with black lettering, which appears to be Champion.
    Would the date be on the manifold, or just the part number ?
    I used one of Sefas Tilley pump leathers, perfect fit - thanks Sefa.
    There are a couple of leaks around the valves, so will put some Graphite tape on tomorrow.
    The case is in beautiful condition.
    Should have gone with this internal link, cocked up somehow.
    https://classiccampstoves.com/threads/14950
    1292958020-IMG_0620_opt.jpg 1292958057-IMG_0617_opt.jpg 1292958090-IMG_0603_opt.jpg 1292958111-IMG_0604_opt.jpg 1292958161-IMG_0607_opt.jpg 1292958194-IMG_0605_opt.jpg 1292958230-IMG_0610_opt.jpg 1292958255-IMG_0611_opt.jpg 1292958284-IMG_0612_opt.jpg 1292958307-IMG_0614_opt.jpg 1292958341-IMG_0624_opt.jpg 1292958381-IMG_0643_opt.jpg 1292958409-IMG_0642_opt.jpg 1292958435-IMG_0627_opt.jpg 1292958466-IMG_0629_opt.jpg
  2. itchy
    Very nice. That is the best looking example of a _______ that I have ever seen. :content:
  3. Paul B
    Paul B Subscriber
    Even without the "man on trapeze' mark, I am willing to bet it's a 2 burner Turner stove made for the military. Maybe late '30's or early '40's. The threaded generator tubes and knurled knobs are the same. Also the burner slides. Many of the same features seen HERE
  4. mackburner
    mackburner United Kingdom Subscriber
    St. Albans, Herts
    No question Champion brand is
    Champion Products, Division of the Turner Brass Works, Sycamore, Ill USA. ::Neil::
  5. Admin
    Thanks Neil
    Much appreciation for the info.
    Quite interested in the company, have you any further info on them ?
    Ian
  6. RonPH
    Looks like a neat stove. Curious though, do you have to prime each of them separately?
    Ron
  7. Admin
    Yes Ron,
    I guess that what makes it a good stove, if one generator goes down, you can still use the other.
    Best
    Ian
  8. mbechtel
    Now THAT is a suitcase!
  9. RonPH
    Thanks Iani, kinda difficult taking the tank and generator out in a rush seeing it has to be screwed on to the manifold. The pump seems to be a tad on the short side for such a large tank too.
    Ron
