Cleaning question on tumbling brass
Discussion in 'Fettling Forum' started by MedicineMan4040, Jun 16, 2019.
  1. MedicineMan4040
    MedicineMan4040 Subscriber
    Guys I just ran the fuel tank of one of my 99's through the tumbler (walnut media only) for an hour and the results though not bad and also not impressive.
    On the way to work I suddenly had the thought that the stove probably has a multi-decade layer of lacquer still on it. Possible?
    And ultimately should I remove the 'old' lacquer then tumble, polish, and then re-lacquer?
    Thanks for thoughts.
    Robert
  2. Tony Press
    If you want to polish, remove lacquer, then polish it and re-lacquer.
  3. MedicineMan4040
    So I was correct in my thinking old lacquer is still there.
    Good on that. I will grab some xylene Monday and re-process.
  4. MedicineMan4040
    The brass tumbling was a first for me....as was using an ultrasonic cleaner.
    One thing about this stove'ing, it's getting me at least familiar with many tools,
    chemicals, processes I've never experienced before.
    Here's 10 mins out of the ultrasonic cleaner, and these results are to my eye pleasing.
  5. Tony Press
  6. MedicineMan4040
    ^Wow! That is the treatise!
    Thanks so much.
  7. MedicineMan4040
    OK, here's the 99's tank post ultrasonic cleaning. Note only 'half' the tank fits in the little
    ultrasonic tank.
  8. MedicineMan4040
    Here's the tank before ultrasonic
  9. kerophile
  10. MedicineMan4040
    Kerophile thanks yet again.
    Here's my 99 post initial cleaning.
    Since this is my working stove this is probably as far as I'll go with it.
  11. kerophile
    Looking really good!
  12. MedicineMan4040
    Thanks Kerophile.
    Part of me wants to go the next step with removing old lacquer, polishing/buffing then re-lacquering.
    I'll sleep on it and decide later :)
