Good morning I was able to ignite, so I went to a slightly windy port and tested it. It wasn't vulnerable to the wind. I was relieved because it was okay to lay it sideways when transporting it. The brass shaft was deformed, so I remade it with stainless steel. The handle was shaped by brass forging. It is easy to use with the handle of the torch. This stove is not delicate and strong against the wind,so I will have more opportunities to use it. My best Regards Honda
You are the artist of the stove world. I expect to see you work in the Louvre Museum in Paris France. Stunning work my friend. Ben
Thank you for all your comments. I wanted to integrate everything because the parts would be lose if it was an assembly style. The other is that it can be packed without a storage case. Use a lot to improve! Thankyou Honda
Thank you for your comment. By the way, I made a small heater attachment of 35g. It's as warm as an Aladdin blue flame stove.
Hit a brass plate to make like a dish and sandwich the coil ,silent burner cap and brass dish. The coil is made by winding a cantal wire. It can be used on various silent burners. Now it's a torch, a stove, and a heater. It's a small joke. Honda
