Coleman 2 burner/tank custom 426B
Discussion in 'Coleman No:426' started by hikerduane, Mar 1, 2020.
  1. hikerduane
    Converted this 426B to two tanks a couple years ago, using two stoves, tanking their tanks and bunsens to make two main burners in one case. Unable to stow both tanks in the case though. Measure eight times, cut once. Only error was not accounting or knowing that each generator varies in distance from the valve, but fixable by moving the bunsen some and remembering the tanks had a specific side they should be at.
  2. Duck United States
    Just east of LaLa land
    You’ve just given me a vision of one with 3 propane adapters!
  3. hikerduane
    You'll need three bunsens to do that.
  4. MrAlexxx
    MrAlexxx Subscriber
    That's pretty cool looking Duane. I like it. Very well done.
    Alex
  5. The Warrior
    In the 'Nois man.
    Wow man, nice work. Never seen anything like that before.:thumbup:
  6. hikerduane
    Thank you guys, something different.
  7. The Warrior
    In the 'Nois man.
    Makes it nice that you actually have two burners, as opposed to a burner, and warming burner.
  8. ROBBO55
    Looks good, Duane :thumbup:
  9. hikerduane
    Thank you, thumb gets a workout unless I have a old kero stove along too.
  10. Harder D. Soerensen
    Denmark
  11. SveaSizzler
    Tucson, Arizona
    That is the dog's balls. Never seen anyone hotrod an old Coleman before.
    The 426 was a 3-burner, but you've made it a dual-tanked, dual-independent burner stove, now right?
    Wow.
    I guess that solves the problem of getting the satellite burner up to the same heat as the main burner, as you'd need under a griddle.
  12. hikerduane
    Yes, tank for each main burner. If the tanks were on the ends instead of the front, the stove would take up quite a bit of space and be hard to regulate the burners, plus too much fabricating to remount parts. No riveting or changes, just cut some holes and slots for the genny and tabs on the tank.
  13. SveaSizzler
    Tucson, Arizona
    Nice. Don't know why the last line got crossed thru. My computer's been acting funny. Locks up the cursor. Hard to get back control.
  14. Duck United States
    How hard is it to pump up the tank on the left without removing it?
  15. hikerduane
    Can be done, a awkward angle, slow and easy if more pressure needed.
