Coleman 391 hot plate
Discussion in 'Other Models' started by hikerduane, May 31, 2019.
  1. hikerduane
    Was given this with some other stoves a few weeks ago. No model # to be seen still on the tank, since it has more cast iron than my 391A, I believe it to be a 391. Very little info out there, but friends have sent me old literature on the hot plate. Top was so rusty, I had to repaint it. Hard time locating proper square nuts, but found some, could not locate zinc coated screws the proper length so reused the old screws. Runs great. After removing the pan under the burners and painting the pans, the main burner throws a bunch of sparks out until warmed up some. I had to drill out the screw on that burner that held the pan to it and the support piece. Took over an hour to drill, redrill, then cave in the remnants to then be able to remove the balance of the screw. Must have knocked loose rust in the plumbing. Tank has a plug on the left side to facilitate dumping fuel and cleaning the tank, some models have this. For comparison, can see my 391A in this area also.
