Coleman 426b
Discussion in 'Coleman No:426' started by Duck, Feb 23, 2020.
  1. Duck United States
    Just east of LaLa land
    I got this 426b a few years ago. It was on OfferUp and the only pic of it was in its box buried under other boxes in someone's garage. The pic wasn't clear but I thought I could make out the 426b on the box. So I took a chance and bought it. Unfortunately the box just fell apart but the stove was is good condition. Just needed a cleaning, a fuel cap seal and a new pump leather. 70D23B31-8731-4AB8-8BBD-7AD7015852E4.jpeg
    F8526C48-B09A-4405-BE45-F1F764B1E05D.jpeg 1DD100DA-611E-494B-BB44-AB64AFE8C244.jpeg AD90F5A7-855E-4ADF-8FC2-760DE783AC67.jpeg
  2. snwcmpr
    snwcmpr Subscriber
    Nice.
  3. SveaSizzler
    Tucson, Arizona
    Did the stand come with it?
    I have one of those stands, later aluminum style, but I'm never sure I have set it up right.
    Seems that there should be slots in the stove bottom to positively access the ''prongs '' on the ends. More of a 413 stand than a 425.
    I have 2 425s and 2 413s. One 425 tank and generator is good. Other one leaks. One 413 tank won't hold pressure, the other one held it only briefly. It did strike for a test burn, but then fizzled out.
    In the meantime, I got a Stansport Propane Adapter. ""Generator'' shaft is too long for the 425s, but fits the 413s nicely. Set up for the 1 Lb Coleman green propane bottle, but I have a rubber hose adapter to connect it with a 20 pound tank. It gets too hot set up that way. Burned the bacon today, before I could pull it off the hot side.
    One day I hope to find a 3-burner.
  4. MrAlexxx
    MrAlexxx Subscriber
    Oh cool. I just grabbed one a couple weeks ago myself. I like the three burners for using the oven. Way better than a two burner. Now all I need is to find a stand like you have there.
    Alex
  5. The Warrior
    In the 'Nois man.
    Very nice.
  6. Duck United States
    Actually that stand came with another 426b that was in sad shape I bought it because I wanted the stand. When I picked it up it also had the propane adapter,2 cans of fuel, and a set of chef trays as a surprise. The OP had cut the top rim of the stove and drilled holes so in the sides so the trays would fit.
  7. SveaSizzler
    Tucson, Arizona
    I found my stand in a thrift store [Savers] that sold stuff by the pound. Metal wares went for $1.69/Lb.
    I also found a '60s Girl Scout mess kit [complete but the wingnut] and some other odd stuff there, other pots and pans, ... a 2 qt Stanley Thermos in OD.
    Sadly, they folded.
