Coleman Candian 4M Tourist 1/63
Discussion in 'Coleman No:4' started by Robert Radcliffe, Oct 21, 2019.
  1. Robert Radcliffe
    Robert Radcliffe United Kingdom Subscriber
    Stockport UK
    I've taken delivery of this very late 4M Tourist stove dated Jan 1963. This is outside the range previously identified by Roland Chevalier in the Guide to Vintage Coleman Products. Roland has confirmed this may be the very latest version of this model so far identified. Very late models have the windscreen tapered only on the top of the outside corner rather than the usual gradual taper along the entire top edge.
    20191021_170832.jpg 20191021_170857.jpg 20191021_170905.jpg 20191021_170912.jpg 20191021_172355.jpg 20191021_170923.jpg 20191021_170930.jpg 20191021_170942.jpg 20191021_171001.jpg 20191021_170846.jpg Screenshot_20191021-181328_Facebook.jpg
  2. presscall
    @Robert Radcliffe
    Great find Robert.
    My 4M of 1960 has the bent wire legs of the later production models but without the very last versions’ windscreen shape, as yours.
  3. Robert Radcliffe
    Stockport UK
    @presscall
    Thanks John, there was a sharp intake of breath when I spotted 63 not because I realised it was a late model, I didn't realise that until I checked my Coleman reference book, but rather I was born in February 63. Close!
  4. OMC
    OMC Subscriber
    Interesting !
    Thank you for posting.
    Expanding on your point re new examples outside the range described in Vintage Coleman Products:
    the ranges stated there:
    4M 1956 -62
    411 in 1964.
    We see on CCS for consideration:
    above is your "1 _ 63" 4M and also of interest
    Blueflame's 411 with tank _ _ 63. That is blank _ 63, no month.
    The differences between late 4Ms and early 411s I'm not clear on, aside from the model # on the case. The impression is the 4M was replaced by the 411, now, seems to be c1963.
    I will offer that re late 4M & early 411 the tank and gen are exact same.
    Dating used stoves referring to swappable tank is a consideration in this as well but it appears, as you suggest,
    4M production ran later, into 1963 and it also appears as though .
    411 production began earlier, sometime in 1963.
    As is always the case it will be good to see more '63 examples that certainly could yet emerge.
    Thanks again for your example and for pointing out it's distinction of the "1_63".
    A heads up and our thanks to @Blueflame as well as his 411 contributes to '63 dating here.
    omc
    PS Our thank to Christer, Ross & Co. for all that is done to improve & maintain the site, transparent to readers :thumbup::thumbup::thumbup:. IE this thread relocated to join the other 4Ms in the gallery.
  5. Robert Radcliffe
    Stockport UK
    Yes very interesting to see the 411. There appear to be a few subtle differences like the position of the pivot points of the windscreen supports being on the corners of the case on the 411 and set back on the 4M and of course the wire feet are a different shape. Vintage Coleman Products has the 411 half an inch deeper at 4.5" rather than 4".
    Can I also thank admin for moving my post to the correct place - apologies.
  6. Robert Radcliffe
    Stockport UK
    Upon further comparison with the 411 another difference I've noticed is the change in level of the side panels on the 4M, the 411 appears to be one level.
  7. Barrett New Zealand
    Northern New Zealand
    Nice stove Robert and very interesting information regarding the years and model changes thank you everyone.
    As these 4's have turned into a mild obsession for me I have another no model stamp 4m shape case stove inbound, but it's got the wrong bits again.
