Coloured heat-resistant paint?
Discussion in 'Fettling Forum' started by John Leah, Oct 13, 2009.
  1. John Leah
    Devon, UK
    I have a compelling need to paint the top of my Bialaddin lamp. The only difficulty I see is that it's red and I'd like to keep it that way but the only heat-resistant 'stove' paint I'm aware of is black.
    So, is any one aware of a source of coloured heat-proof paint?
  2. Bom Bom Bom Bom
    Hi John,
    Halfords do a Very High Temp paint that is bright signal red.
    Also check out Stove Paint as one example. There are others if you Google "Stove Paint".
    Cheers, Graham.
  3. John Leah
    Devon, UK
    Perfect, just what I was looking for, thanks :)
  4. David Shouksmith
    David Shouksmith Subscriber
    Let us know if it works, please.
    Don't want to rain on your parade but a pound to a pinch of snuff, it doesn't - otherwise it would be used on these hoods already, instead of vitreous enamel, surely?
    Still, we live in hope! [-o<
  5. Pitsligo
    Olympia, WA, USA
    Would automobile engine enamel be adequate? I just coated an old hurricane lamp Ford-blue, out of a rattle-can --came out quite nice, with its brass accents-- and I recall the hardware store also had bright red, but I don't know if the lamp/heat are comparable.
    For that matter, I don't know if it's available over there.
    Alex
  6. anlrolfe
    anlrolfe Subscriber
    Louisville Kentucky, USA
    If I may,
    Try to find someone who does the pottery gig. They may be able to match a suitable glaze and fire it in a kiln. This stuff is made to handle the temps of a hood. The only questions that I have are 1) will they be a solid color 2) will they be chip resistant.
    AR
  7. Rick b
    Boise
    Hi AR, I worked in a dinner wear factory in the glazing dept years ago in Seattle. I am not completly sure, but I dont think the glaze would be able to attach itself to the metal surface; you dip the piece into the glaze (or paint it on with a brush) and it is absorbrd into the pottery while also forming a film on the outside of the surface.
  8. anlrolfe
    anlrolfe Subscriber
    Rick b,
    Thanks, that's good to know.
    Do we know anyone who works for Kohler, American Standard or someone who still puts glaze on cast iron tubs & such?
    Surely the process would be similar?
    AR
  9. John Leah
    Devon, UK
    Well, maybe not so perfect after all :frown:
    According to the spec it should be OK at the temperatures the top will reach but the cost is the issue: It's £14.95 per tin which is possibly just about OK but they have a minimum order qty of two tins :x
    £30 to tidy up the top of a lamp I only paid £8 is not really what I ought to be doing.
    I've been looking at a few other possibilities Google found for me but so far haven't found a red paint. I'll keep looking though.
  10. Bom Bom Bom Bom
    Hi John,
    Try the Halford's stuff. They have two bright red options - one in a spray can and one brush on. From memory the brush on one has a higher temp resistance. They need to be applied to bright metal though so you'll need to chip off all the existing enamel on the hood.
    Cheers, Graham.
  11. fyldefox
    fyldefox R.I.P.
    Hi John
    I think David's views on vitreous enamel are right; if spray paint could take the heat it'd been done a while ago.
    If you aren't too fussy about a change in the "style" of your lamps hood ( and plenty have been changed about ), you can still get new Black ones for about £16 plus p&p from Bairstows.
    By the way they are still in business and are bringing out a Chrome M320 !
  12. shagratork
    Tell all, Keith!! :shock: :shock:
  13. parramethtrol
    parramethtrol Subscriber
    i could do with a chrome 320 to go with my chrome bowlfire :D/ :D/ :lol:
  14. John Leah
    Devon, UK
    I managed to get some from my local factors this afternoon at £6.99 for a large aerosol. I'll give it a try and report back.
