Companion: Regulated Silent Single Burner
Discussion in 'Companion' started by Tony Press, Dec 3, 2017.
  1. Tony Press
    Here is a fine Companion single burner stove with a regulated silent burner. Made in Australia under licence to Sievert.
    Someone's ownership marks.
    It's a pity the bakelite pump knob is broken. I filed the rough edges.
    Note the big spirit cup.
    Each of the legs had this kind of lump.
    The bits:
    It came with a rusty trivet. This is a restored one.
    Up and running:
    As it came:
    Companion are a very fine stove; and having one fitted with a silent burner makes this stove very special.
  2. kerophile
  3. kerophile
  4. Tony Press
    Thanks, @kerophile
    I’ve wondered about this phenomenon.
    I thought it must have been either tin or solder.
  5. ROBBO55
    @Tony Press
    Nice stove Tony and burning well. As you say the regulated burner is unusual. :D/
    I'm just wondering what is the overall height of the stove?
  6. Tony Press
    @ROBBO55
    The height to top of leg is 22cm. It’s the same as my silent Companion and a Primus No. 1.
    With silent Companion.
    With Pre-1911 Primus No. 1.
  7. ROBBO55
    @Tony Press
    OK. That shot the bottom out of that theory. 22 cm is the same height as all the fixed leg Companions I have.
    I haven't seen those bludges on the legs/supports of any other Companion stove.
    So I thought they may have cut and 'but welded' the legs/supports to changed the height for the regulated burner (rather than retooling).
    I think the Bakelite pump knob is also unusual.
  8. Tony Press
    @ROBBO55
    If you look at the matched Companion two photos up, you’ll see that it has a little “lump” on the right hand side leg a bit higher up.
  9. ROBBO55
    Thanks Tony. The spot on the other stove in the photo didn't register with me when I was looking at it.
    George is right again and it is a build up of tin. :thumbup:
