Comparing the stainless and aluminium Sigg Tourist Cook sets.
Discussion in 'Stove Forum' started by Robert Radcliffe, Sep 14, 2020.
  1. Robert Radcliffe
    Stockport UK
    The cooksets in question are the ones designed for the Svea 123. It turns out there are some significant differences besides the obvious.
    Immediately obvious is the difference in height, the aluminium set standing about 12.5cm and the steel version less than 11cm. This is because the large aluminium pan is taller than the steel equivalent, the diameters are the same. The volume of the aluminium pan is about 2300ml, the steel 2000ml or 3.5 pints. An odd decision as it means the burner bell of a 123 must be removed in the stainless set, as the stainless pan is not as high and the bell projects too far to allow the lid to be placed securely. If the bell is left on the lid pivots on it.
    The smaller aluminium pan is also larger but only marginally both being around 1400ml or 2.5 pints.
    The stove plate and wind shield are identical in size although I prefer the polished finish of the aluminium set to the brushed matt look of the stainless set.
    Another disappointing difference is the much smaller lip on the bottom of the steel pans for locating them on either the windshield or the other pan. The lip is 3mm on the stainless pans and 7mm on the aluminium pans. This means the steel pans do not seat as securely as the aluminium pans, to the extent that I would hesitate to stack the steel pans. A real shame as this is a great feature of the set in my opinion.
    So in summary although I consider steel a superior material for pans I think the aluminium set is the better designed and the more practical set.
    20200914_084858.jpg 20200914_084926.jpg 20200914_083103.jpg 20200914_083423.jpg 20200914_083358.jpg 20200914_083820.jpg 20200914_083925.jpg 20200914_084010.jpg 20200914_083658.jpg 20200914_083118.jpg
  2. Robert Radcliffe
    Stockport UK
    I've just realised the sentence starting ' The smaller aluminium pan is also larger' is confusing. I meant the smaller of the two aluminium pans is larger than the equivalent steel pan.
  3. Twoberth
    England
    Thanks for the comparison.
    How do the pan bodies compare thickness wise?
    Stainless steels are usually stronger than the aluminium alloys used in cooking pans, but have poorer thermal conductivity. For these reasons I would expect the stainless pans to be thinner, and this may account for the smaller lip. Are they noticeably thinner?
  4. Robert Radcliffe
    Stockport UK
    @Twoberth Hi I don't have an ideal set of calipers but I used my leatherwork calipers. I got 0.95mm for the aluminium and 0.8mm for the steel. As the calipers are designed for a flat surface and were measuring a slight curve these will be slightly over the true thicknesses but not by much.
  5. Twoberth
    England
    Many thanks.
  6. snwcmpr
    snwcmpr Subscriber
