Converting a knackered silent burner into a regulated silent burner
Discussion in 'Fettlers Master Class' started by Twoberth, Apr 10, 2021.
  1. Twoberth
    England
    This Primus silent burner was knackered: the tubes were blocked and the nipple seat threads were stripped. But other than that the burner was in decent condition.
    So I decided to cut it open and unblock it, and then convert it into a regulated burner with a new jet.
    This is how I did it.
    First I cut and unblocked the burner, cutting the tubes just above the jet seat
    Then I inserted a regulator barrel that I devised from measurements taken from an Optimus 111 burner (details further down).
    The barrel has a drilled and threaded inside, and takes a normal Optimus 111 spindle, packing and fittings - except that the pinion teeth are ground off the spindle so the gas can pass easily from the inlet tube to the nipple
    There is only one inlet for the gas into the regulator barrel, this feed come from the left hand tube in the photos. The right hand tube is redundant, and is used for support only.
    Next the barrel (without nipple and fittings) was brazed in place using Silverflo 55 braze alloy and Easyflo flux.
    and the fittings and nipple are fitted
    New washer from @Spiritburner, and the burner is fitted on an old SVEA tank and works as it should from full throttle to simmer.
    So, from scrap burner to regulated burner in an afternoon. I am very happy with this recycling project.
    Regulator barrel internal details. The outside of the barrel has flats ground in a vee (visible in photo 6) so that it is cradled securely between the two long tubes. There is also a small flat ground on top of the nipple hole so that the nipple makes a gas tight seal.
    I now have made three of these regulated burners. The two silents were from knackered burners.
    The roarer burner was made completely from scratch and will be posted separately.
  2. Ian
    Ian Subscriber
    West Yorkshire
    Excellent stuff! :clap:
  3. The Warrior
    the 'Nois man.
    Fantastic work.
  4. CRAZY CRAB
    CRAZY CRAB United States Subscriber
    Addlestone UK
    now that is one good idea
  5. presscall
    @Twoberth Well done Duncan and bravo to whoever nominated your post to go into the Fettlers’ Master Class.
  6. Twoberth
    England
    Thanks everyone.
  7. Harder D. Soerensen
    Denmark
    Definately a worthy Master Class example.
    Well done @Twoberth
  8. Optimust
    @Twoberth.
    We must thank You for shareing your
    very good idea;s with us all, very well
    described & illustrated. Best to you.
    Optimust. :clap:
  9. CRAZY CRAB
    Addlestone UK
    if i sent you one of me spear burners, how much to convert it, please
  10. Big Si
    Big Si Subscriber
    Amazing work there.
    Si
  11. Twoberth
    England
    @CRAZY CRAB Thanks for your request, but I don't intend to convert other peoples burners as I have too many other house and hobby projects to do. The conversion is not as hard as you may think. You don't need a lathe if you start with 1/2 inch brass bar, only normal workshop tools and the correct taps.
  12. CRAZY CRAB
    Addlestone UK
    many thanks, no probs, :)
  13. Twoberth
    England
    Thanks Harder, Big Si and Optimus.
  14. Rangie
    Rangie Subscriber
    Excellent fettle, well done :thumbup::thumbup:
    Has given me inspiration to try it on the biggest Liberty silent, will report back.... :mrgreen:
    Alec.
  15. Twoberth
    England
    Thanks Rangie. I look forward to your results.
