DIYS NRV Tool
Discussion in 'Fettling Forum' started by Doug L, Nov 19, 2019.
  1. Doug L
    Doug L Subscriber
    USA
    I needed a NRV tool with a open slot so I came up with this idea.
    Its a 1/2 inch extension rod from a ratchet set clamped in a machinist vice.
    You need a drill press with a 1/4 inch cutoff wheel clamped into the chuck.
    That's all you need. Just slowly pull the part into the wheel and cut yourself a NRV tool.
  2. ROBBO55
    Worked nicely Doug. :thumbup:
    I also like to use a ratchet (and socket ) with my DIY - NRV tools.
