Eezy-Fyre Flame Spreader
Discussion in 'Fettling Forum' started by Sedgman, Jul 20, 2021.
  1. Sedgman
    Sedgman Subscriber
    The Eezy-Fyre stoves are Australian made, not common and have a patented burner that is unique. They were made from about 1941 to 1951. The tri-clawed flame spreader which is usually marked clearly in large letters EEZY-FYRE was the same shape across the years and the two models and two variations. Some early models also had a flame spreader that was not marked.
    My double burner model came with only one flame spreader and the single burner Eezy-Fyre came with the unmarked version (see photos below). I have used this latter one as a template to construct a second flame spreader for the double burner stove.
    I have tested it and it works satisfactorily so I'm pleased.
    I started with a section from a piece of 10 mm thick bar and cut it with a disk on the angle grinder. Then used a grinding disk to shape the underside to resemble the template fitting. Not perfect but good enough.
    The completed flame spreader.
    The new and template flame spreaders and the pieces from the original 10 mm bar.
    Starting to work on the underside of the new one.
    The top sides of the new and template. I just had to stamp it too!
    The undersides.
    In use.
    The beautiful old stove (single burner) testing out the new flame spreader.
    Iain
  2. ROBBO55
    Nice work, Iain.
    It's certainly solid enough and producing a good flame pattern. :thumbup::thumbup::thumbup:
  3. Tony Press
    Excellent!
