Effekt 15 twin burner
Discussion in 'Ernst Hãhnel' started by optipri, Nov 7, 2016.
  1. optipri
    optipri Subscriber
    This stove has probably not been used very much from what the burners show. But it has been mis-treated. The legs are a bit damaged and the top surface has rust spots, probably because of storing in a damp place.
    Underneath it is in great condition and because of that I descided not to repaint it. Just clean the rust off and then I treated it with black shoe polish.:idea: The result is quite ok but of course not as new.
    Bo
  2. Tony Press
    @optipri
    Are you going to light it? It's a fine looking stove.
  3. optipri
    optipri Subscriber
    I really should try to light it up but I am not so keen on doing that. My dilemma is too many items that has to be renovated and a lot of sealings that has to be replaced only for a test. After that they will probably be for display only and the sealings will dry out once again after a numberof years. So because of this I only have a few items for daily use I keep in working order.
    Bo
  4. geeves
    geeves New Zealand Subscriber
    Christchurch NZ
    Thats fair enough for stoves other people have but this is the first of these Ive seen and alcohol stoves dont need a lot to make work
  5. gieorgijewski
    gieorgijewski Subscriber
    different EFFEKT 15
    with two different burners - brass and steel/brass
    photo from ebay
  6. snwcmpr
    snwcmpr Subscriber
    Nice, Bo.
