Hey Kerophile, I still am clueless as to the case size. Is is larger than the 111? What are the dimensions if you dont mind. Weighwise too. Ron
Hi Ron, I have consulted the Catalogues for you: The Enders 9060D: Case Size = 21.5 x 19 x 8.5cm or approx 8.5 x 7.5 x 3.5 inches Weight = 1.6kg or 3.5 pounds Tank Capacity = 0.33 litres or around 12 fl oz. Burn time per tank about 2 hours. I would estimate max power at approx. 3kW or 10,000 BTU/hr from the Manufacturers figures. Optimus 111C: Case Size = 18 x 18 x 10.5 cm. or approx 7.1in x 7.1in x 4.1in Weight = 1.64Kg or 3.61 pounds Tank Capacity = 0.35litres or 12 fl oz. Burn time per tank about 2 hrs at high output. Power Output given as 3kW or 10,236 BTU/hr Trust this helps, Best Regards, Kerophile.
Hey Kero, thanks, that gives me a perspective of the Enders 9060. And its just as heavy as the 111. Cheers Ron
Hi, here is a link related to the fettling of this Enders 9060 stove: https://classiccampstoves.com/threads/enders-9060-d-problem.8075/ Best Regards, Kerophile.
Hi, another day of the lock-down and an opportunity to dig out some of one’s stoves to check they are OK and still performing as designed. Here are some images of my Enders 9060D on coffee duty this morning. Best Regards, Kerophile.
