Enders 9060D Silent
Discussion in 'Enders' started by yonadav, Jun 12, 2011.
  1. yonadav
    Israel
    Here is a nice Enders 9060D that I got recently. Except for being dirty, it was pretty much in working order when I got it. There was some pressure leak from the tank cap, which I solved by just flipping the seal over. The pump leather was dry, but came back to life with some machine oil. (This is lucky, since the Enders leather cup is pressed together with the backing metal ring, which makes replacement a problem.) I cleaned the burner and valve assembly with a short bath of Citric Acid, and now I have a nice, very powerful stove. It boiled a liter of water in 3:45 minutes.
    I decided to add a well known object (the coke can) in stove photos, for easy size reference
    The flame is ferocious, but clean blue
    And it has a beautiful simmer
    Yonadav
  2. mr optimus
    mr optimus Subscriber
    Hi Yonadav what a score a very nice stove indeed the flame control is superb on it from a very powerfull flame to a very gentle simmer infact the flame control and patern on the Enders9060D looks very much like a modern butane/propane stove a cracking little old classic a head of it's time
  3. threedots New Zealand
    A nice stove yonadav.
    They certainly are very different in design to the usual Swedish petrol stoves.
    A good, solid German stove. Grunty as well.
    Well worth keeping that one. Cheers, John
  4. Big BTU
    Wow super clean Enders Yonadav! Great stove, you will get alot of use out of it. I love their simmer and power too.
  5. Chef BC
    Nice score Yonadav, I think this stove will become a favorite of yours given enough time. You have done well to get such a uniform flame, it looks superb! Just be sure to push the valve/needle levers inside the case before folding over the lid, the weak point is the brass tank. This will cause deformation of the tank. :( :( :(
    Harold/Chef BC
  6. gunsoo
    Hi Yonadav.
    wow i like it indeed. :thumbup:
    small size,and powerful flame, also beautiful
    flame .
    congratulation !!
    Gunsoo
  7. Grebby
    Please ignore this I just posted in the wrong thread
    Grebby
  8. presscall
    Coincidentally, Grebby, I've not long ago posted this - should answer your questions about the differences between the two stoves
    Enderses
    The 9061 probably cost more new, and likely still does bought second-hand now.
    Which is best? Identical burners and output, nothing to choose unless you favour the ingenious telescoping controls on the 9061 and the way it can be put into use a little bit quicker and easier than the 9060D can.
    In terms of design, the MSR is very different from these 'stoves in a box' but in terms of heat output and quiet operation, similar. The benefit of the 111T is that it'll take paraffin as fuel, whereas the Enderses and the MSR are white gasolene/Coleman fuel/Aspen 4T/panel wipe (pretty much the same fuel).
    Some, myself included, prefer using paraffin in stoves, particularly since its possible to get it cheaper than the other fuels in the UK (except possibly the panel wipe).
  9. presscall
    I guess I just did too answering your questions!
    Oh well.
