Enders 9061D "Fettle"
Discussion in 'Fettling Forum' started by The Warrior, Jun 27, 2020.
  1. The Warrior
    the 'Nois man.
    Changed out the seals in the pump tube, and gave it a new fuel cap seal.
    Pump tube out. Old seal:
    Success:
    Some leather and oil crud in the tube:
    Cleaned out:
    Leather wasn't in too bad of shape:
    Disassembled. The original cup here, has a "barrel" in the center of it. It really adds to the stability of the way it slides on the shaft, to release the air:
    Old seal, as expected, was brittle:
    New seals and cup. The new cup doesn't have the same barrel in it:
    New seal on:
    New cup assembled:
    I just didn't like how it fit. Because the barrel isn't in the middle, it sits wonky on the shaft. I didn't get a good photo of it, this is nothing compared to how crooked it gets:
    Reinstalled the old:
    Applying the other seal:
    Seated:
    Placing the tube back in:
    Tightened up:
    Old fuel cap gasket:
    Brittle, but not overly hard to get off, especially with no heat applied. The new seal is a Basnetts No.2 size gasket:
    Fits perfectly:
    Priming:
    Success. Of course, it worked before I applied the new seals, just works better now:
    Thanks for looking.
  2. presscall
    Great work.
    Ha! I’ve got some of those, they fit ‘small’ Coleman fuel caps if I remember rightly. Well-spotted crossover application.
  3. The Warrior
    the 'Nois man.
    Thanks.
    Yep, they fit the 3 piece Coleman fuel caps.
