Enders 9063 Questions?
Discussion in 'Enders' started by Harder D. Soerensen, Feb 21, 2018.
  1. Harder D. Soerensen
    Denmark
    I am now the lucky owner of an Enders Baby (powerful little beast!). I have a few questions in regards to this.
    1: While fettling I noticed that there are three different types of pot support - any ideas why? And which one is considered the best/your preference?
    2: I haven’t dared yet to unscrew the regulator spindle, because after some full turns it starts to be very tight. Is it correct that you only need to remove the regulator-nut, and then turn the spindle counter-clockwise until release?
    3: I have no problems with getting the pump tube out of the tank - but How do you get the pump shaft out of the tube?
    (Knowing my own “power-to-patience” ratio, I have bitterly learned, that often are better to ask questions first - instead of paying afterwards (or getting stitches).
  2. kerophile
  3. Ray123
    Ray123 Subscriber
    New Hampshire, USA
    Harder, I think you just got lucky with the 3 pot supports. Usually the 9063 came with only one, either the round style or the 4 armed model. Possibly the style was determined from the years of manufacture but I don't know for sure.
  4. kerophile
  5. Harder D. Soerensen
    Denmark
    @Ray123
    Unfortunately I am only the lucky owner of the first pictured four-legged spiderlooking pot support.
    It has a good adaptability and wind protection - but it may seem a bit flimsy.
    I haven’t seen the two other types up for sale singlewise.
    @kerophile
    Thanks for the links - will do a closer study. As for now it burns quite powerfull, but I like to know the inside of my stoves
  6. gieorgijewski
    gieorgijewski Subscriber
    about pot stand...
    minimal mug diameter is 6 cm
    imo -on last pictures distance is too big
  7. Majicwrench
    Majicwrench Subscriber
    I also recent acquired a 9063, with that "spider" type of pot support, ,which works, but seems a little flaky, doesn't really mount securely on tin.
    THe pump tube is held in by the gasket, pick gasket out and tube will come off.
  8. Harder D. Soerensen
    Denmark
  9. Tony Press
  10. Harder D. Soerensen
    Denmark
    @Tony Press
    I saw yours when trying to find out how many versions of pot support Enders made. I actually find yours to be a bit better designend than the original Enders steel bar version. (I have yet to try other versions) Yours have a good short distance between them. But I will have to settle for the spider version, since I don’t have neither means, patience or skills to make a (very well made) pot stand like yours.
  11. Tony Press
    @Harder D. Soerensen
    I will make some for you. :content:
    I’ve got a lifetime supply of stainless steel rod.
  12. Harder D. Soerensen
    Denmark
    @Tony Press
    Thank you - I would really apprieciate that!
  13. Tony Press
  14. Majicwrench
    I used mine this weekend with the spider version, and it worked fine.
    @Tony Press , mine is not a powerhouse, , probably a bit less so than an 8R, what are your thoughts on yours?
  15. Tony Press
    @Majicwrench
    It works well enough for its prime task of making espresso - you don’t want to force the heated water through the coffee too fast; just nice and steady.
    I haven’t compared it to an Optimus 8R, but I think the 8R would be a bit more versatile.
  16. Ray123
    Ray123 Subscriber
    New Hampshire, USA
    The 9063 Baby, just by having a pump, should start up a bit more lively than the self pressurizing 8R. After the 8R builds to full pressure maybe they are equal but I think the 9063 would still have at least a little power advantage.
  17. Tony Press
    You might need to fiddle with the end bends to get a snug fit on your box.
    I’ll put them in the post this week.
  18. Harder D. Soerensen
    Denmark
    @Tony Press
    Wow - well done!
    Thank you Tony.
    It must be nice to have both tools and skills for such makings!
  19. MrAlexxx
    Tony is a good guy! Well done. :)
    Just reading this post as have just picked up my own little "baby". Spider web pot leg system. Maybe a little worse for wear than your "baby" Harder but still a baby to play with. :)
  20. Harder D. Soerensen
    Denmark
    @MrAlexxx
    Indeed @Tony Press is.
    Have fettled mine a bit since top picture was taken.
    This is present state.
    I really like this little powerhouse - which is now placed on my “never ever sell-shelf”.
    Looking very much forward to try TSPS (Tonys Special Pot Support)
