ESAZA, spanish clon 8R Butane stove
Discussion in 'Other Countries' started by pau-i-amor, Dec 6, 2019.
  1. pau-i-amor
    pau-i-amor Subscriber
    17190 Salt, Catalunya
    Seller said me it burn alcohol...
    500 Ptas. Nowadays is arround 3eurs or 3 USDollars, but in the '60 it was a blue-collar week salary... "The little great cooker"
    It seems another 8R clon, but It's a rare rechargeable butane stove.
    A butane burner...
    Refiller cap with a valve...
    ESAZA made some cooking utensils like coffee grinders, slicing machines, pressure cookers, etc...
  2. Simes
    Simes Subscriber
    Well that's something you don't see every day. A very interesting adaption and it makes you wonder why produce a butane version almost identical.
  3. gieorgijewski
    gieorgijewski Subscriber
    Wow - with wow...
  4. gieorgijewski
    if possible - try to check year of that patent number...
    impressions - late 70-ties early 80-ties
  5. itchy
    That is crazy cool. John (Butane-conversion) @presscall should get a kick out of it.
  6. kerophile
    Hi @pau-i-amor Great acquisition!
    Looks like a “missing link” between a self pressurising liquid fuel stove, and a Liquified petroleum gas stove.
    Here is another “missing link” stove:
    RM Rambler, the Missing Link? *
  7. Harder D. Soerensen
    Denmark
    WOW - never seen that one before!!
    Congrats on a GREAT score!
  8. Ed Winskill
    Just when you think you've seen them all....
  9. pau-i-amor
    People in Spain use Butane for cook. I discovered liquid fuel cookers twenty years ago...
  10. Simes
    Simes Subscriber
    Hi @pau-i-amor I can appreciate the dash for gas during the late 60's early 70's and the rapid decline then with the public of liquid field stoves.
    The RM adaption sort of seems a logical move, but to produce a butane 8r would seem to take the process at that time a bit too far.
    It's a wonderful adaption, but the market was moving so quick then.
  11. pysen78
    pysen78 Subscriber
    I agree! It immediately reminded me of this old post:
    https://classiccampstoves.com/threads/converting-a-gas-guzzler-to-lpg.16242/#post-163596
    @pau-i-amor Great catch! It is a brilliant conversion really. What you now have is probably one of the best butane stoves for cold weather use. It utilizes cheap butane, and thermal feedback should take care of vapourization in cool weather.
    Would you care to deconstruct the filler cap, so someone could have a go at reverse engineering of it?
  12. pau-i-amor
    Hi @pysen78 , Re-fill valve seem's like a Schrader valve without a core.
    Pushing the pin you can see when the valve is close...
    or open:
  13. The Warrior
    the 'Nois man.
    Too freakin' cool man, wow...
  14. pysen78
    pysen78 Subscriber
    Thank you for the detailed pictures, now I have to put my thinking cap on. :)
  15. SveaSizzler
    Tucson, Arizona
    Fascinating unit. Is the burner compatible with an Optimus tank for benzine/white gas/naptha? Or do I see a little 'joggle' in the tank-to-burner fuel line that prevents such tampering?
  16. presscall
    Indeed I have Itchy.
  17. pau-i-amor
    @SveaSizzler I think burner isn't a propane/butane adaption. I see a cut and paste action: There is a propane burner intead of the original burner.
  18. Nicola Francesco Elia
    Nicola Francesco Elia Subscriber
    Hello, I have just acquired this same stove and I confirm that it is all original, including the burner, as shown on the instructions paper.
    Mine is NOS too. So, is this a butane stove? How could be refilled?
    Many thanks for any help.
    Nicola
  19. pau-i-amor
    @Nicola Francesco Elia
    Excuse, Nicola! I just saw your question. This is a butane stove. You could buy a butane canister and refill. It seems you refill it like a lighter.
  20. Nicola Francesco Elia
    Hi Paul that’s what I thought, many thanks for your suggestion.
    Nicola
