Fabricate a case/tin for Optimus 80?
Discussion in 'Stove Forum' started by hikerduane, Sep 14, 2020.
  1. hikerduane
    If you made a case or pot stand for a Optimus 80 stove or similar, what did you use? I was offered a Optimus 80 and Svea 123 with some fuel caps for a great price, but both stoves don't have a windscreen or case for them. The 123 I could match with my Sigg Tourist set, but the 80 I would have to make something or a case from another stove or even see if it would work in the Sigg set.
  2. Ian
    Ian Subscriber
    West Yorkshire
    Is it a large 80 or a small one?
  3. kerophile
  4. Sternenlicht
    Sternenlicht Subscriber
    Hürtgenwald
    Hej Duane,
    I'm using a 71 without tin, but with selfmade legs. Stove with legs is about 300grs only.
    Ciao, Bastian
  5. Ian
    Ian Subscriber
    West Yorkshire
    Very nice, Bastian.
  6. Ian
    Ian Subscriber
    West Yorkshire
    A 400g Nido milk powder tin looks like it will be suitable candidate for a 123 house.
    It could be time to take a stove or two (or at least a tape measure) down the supermarket to check out suitably sized cans. It's a bonus if they have something nice in them.
    Deja vu
  7. Sternenlicht
    Hürtgenwald
    Thanks Ian, but not my idea, Pillepalle inspired me to do that!
    Ciao, Bastian
  8. OMC
    OMC Subscriber
    Glad you're posting Duane [-o< , thank you,
    a couple links came to mind:
    brit no.7 case
    when considering no 7 case for the Op 80, consider the No.7 fix credit kerophile
    and more options
    hobo ETC. and
    gotta run
  9. Ian
    Ian Subscriber
    West Yorkshire
    Bastian, the late Nordicthug also did a similar thing some years ago.
  10. Sternenlicht
    Hürtgenwald
  11. hikerduane
    I have a military setup already. Thinking cheap, cheap! Maybe a coffee can opened up some, couple pieces of steel placed in holes drilled horizontally. Didn't realize there were so many threads on this, depends on search wording. Thank you, these stoves should arrive today.
  12. Duck
    Duck United States Subscriber
    Just east of LaLa land
    still have to make a heat shield for it but that should be easy
  13. hikerduane
    Ah, wasn't thinking of that. Have a tobacco tin lined up even. :(
    Left some room from when I expanded shelving for my 96's.
  14. kerophile
  15. kerophile
  16. Harder D. Soerensen
    Denmark
    @Sternenlicht
    Hi Bastian - what did you use to make that three legged pot-stand - I really like that design!
  17. Sternenlicht
    Hürtgenwald
    @Harder D. Soerensen
    Thanks Harder!
    I took a brass band, I mean it was about 0,5mm thickness and brass tubes with 3mm inner diameter. Everything is brazed, but I think solderring should also work.
    The wind shield is made from a aerosol can.
    For the legs I took 3mm brazing rods. Not stainless, but they also work for some years now.
    Ciao, Bastian
