Flame not Spreading
Discussion in 'Fettling Forum' started by Rayo, Oct 12, 2017.
  1. Rayo United Kingdom
    United Kingdom
    Bought this Veritas pint stove at a charity shop yesterday and thought I would try and fire it up today . On closing the valve and pumping hey presto it fired up but the problem is the blue flame is only visible on about 25% of the spreader
    Any ideas on why it's not all the way around the spreader.
    who ever had it previous had tried to clean it but obviously gave up.
    Any idea of age would be appreciated.
    thanks in advance
  2. HunterStovie
    Town of Parker, Colorado, USA
    Partially blocked fuel jet?
  3. Rayo United Kingdom
    United Kingdom
    I'll try cleaning the jet with a pricker hopefully that might do it
    Thanks
  4. ROBBO55
    If cleaning the jet doesn't work check that the nipple is installed properly and not at an angle.
  5. hikerduane
    Northern Sierra Nevada
    You can also dimple the exit side of the nipple with a small drill bit, any burr on the exit side or within the nipple will distort the vapor. Carbon build up on the bottom side of the burner.
