Flat pack burner - 3
Discussion in 'Fettlers Master Class' started by Twoberth, Nov 2, 2018.
  1. Twoberth
    England
    Further to recent posts on this, I decided that I could make the burner bell more robust by drilling double holes rather than slots for the air intakes, then cutting a slot between the holes and folding the flaps inwards. This time I used steel for the lipstick tubing and the flame plate.
    Also I brazed the 'wing' corners together at the top of the bell after bending to shape.
    The jet used on this test lipstick was a normal 0.32mm jet with the sides squashed in to give approx. a 0.23mm hole, and brazed into a circular cap and onto the steel lipstick tubing.
    Steel flame plate made from scrap.
    Standard brass gauze packing was used and heat transfer back into the lipstick is good, so vaporisation is maintained and the flame is stable over long periods. Some more 'squashing' of the jet is needed to get rid of the yellow flame tips.
    An old Monitor tank has now been made into a working stove, and elevated to morning brew duty.
    Incidentally, a B&Q 10mm plumbing pipe coupler thread is a slightly loose fit on both Monitor and Swedish '96' tanks, and provided a good thick lead washer is used it provides a good tight seal between lipstick and tank. Fettlebox washers are ideal.
  2. shagratork
    Brilliant! :clap:
  3. hikerduane
    Great work, I would have made a wreck.
  4. OptimusPrime Canada
    Kamloops bc
    Even thought I feel expletives are in order...I will refrain for fear of being censored..
    But that is just......great! :clap: Never ceases to amaze me the talent and perseverance I witness here....
  5. CRAZY CRAB
    addlestone
    me vid on first test,
  6. Harder D. Soerensen
    Denmark
  7. Tantra
    Tantra Subscriber
    China
    Radius 113/36 burner is 99% same
    Gasoline burner
