Fuelhose for old Optimus nova
Discussion in 'Stove Forum' started by Bjartafari, Jul 30, 2020.
  1. Bjartafari Norway
    Norway
    Hi and thanks for joining the forum!
    I have a Optimus nova from ca. 2005. It has been a bulletproof stove. However during the last trip the fuelhose "clamp(?)" broke of and it is leaking. Picture attached.
    Have tried to contact Optimus via email, but no answer.
    I have a newer backup nova stove, but it has a different hose connector.
    If anyone know where I can get a replacement fuelhose with the CEJN connector let me know! I live in Norway
  2. Tron
    Tron Subscriber
    Norway
    Kan du ikke sette på en ny klemme? Evt. bruke en liten slangeklemme, som disse: Slangeklemmer, 1-ørede, 5 stk.
    Evt. prøve hos TESS om de kan fikse en klemme. Jeg har ikke sett disse til salgs noe sted på lenge, tror ikke du får tak i den. Du kan prøve fogas.se, sende de en epost.
    English: I suggest to have it repaired (with reference to some Norwegian sources). I have not seen these for sale in a while. They are not listed at base-camp or at fogas.se.
    Tron
  3. Bjartafari Norway
    Norway
    Thank you very much Tron. Will try a self fix, will let you know if it works.
    Tusen takk!
  4. Staffan Rönn
    Stockholm, Sweden
    I can confirm these hoses are regretfully no longer available. As Tron suggests, it should be fixable by a hudraulic work shop. The clamping is pretty standard.
  5. Lennart F Sweden
    Vänersborg, Sweden
    TESS has a limited stock of small fittings - the Norwegian shops with most small fittings and fasteners on shelf seem to be TOOLS - I've been hunting connections and sealings several times around the Oslofjord area.
  6. Bjartafari Norway
    Norway
    Staffan and Lennart thank you for info and soulutions:)
