Ginge Range
Discussion in 'Denmark' started by Sternenlicht, Oct 22, 2020.
  1. Sternenlicht
    Sternenlicht Subscriber
    Hürtgenwald
    This stove seems to had a hard life, some dents, pinholes, the soldered seam between tank and burner were broken. Also the seam to one of the side caps. The iron cast is also broken, but this is not unusual.
    Compared to the other Ginge Ranges my has a square plate on bottom of the quadrupedal trivet.
    I do not know how old it is, I assume it is from the 1950's. Maybd someone knows better?
    I like this stove and will use it for large pots in my garden.
    Ciao, Bastian
    IMG_20201022_204848.jpg IMG_20201022_203329.jpg IMG_20201022_203339.jpg IMG_20201022_203440.jpg IMG_20201022_203454.jpg IMG_20201022_203500.jpg IMG_20201022_203517.jpg IMG_20201022_203535.jpg IMG_20201022_203601.jpg IMG_20201022_203851.jpg IMG_20201022_204556.jpg IMG_20201022_204600.jpg IMG_20201022_204747.jpg IMG_20201022_204839.jpg
  2. Tony Press
    Thank you. That’s an interesting stove.
  3. Harder D. Soerensen
    Denmark
    I have the same stove.
    A Ginge Range(?)
    Its a workhorse of a stove and is used for large pots and pans under our Lampie gatherings here - it can take quite a weight and runs stable for hours.
  4. Sternenlicht
    Hürtgenwald
