Hãhnel 'Perfektus' No.10
Discussion in 'Ernst Hãhnel' started by igh371, Aug 29, 2017.
  1. igh371
    Hãhnel 'Perfektus' No.10, date uncertain, but possibly early 1920s as the riser has no hex for assembly/disassembly unlike those shown in later catalogues. The riser and tank fitting are also odd in having plain surfaces and in relying entirely on basic heat-proof washers for the seal. The filler/pressure release set up is different to other examples in the gallery. Other variants have either a combined pressure release and filled cap (link), or a combined filler/travel cap and a standard pressure release screw (link). This current example has a more basic arrangement of filler cap, with the Hãhnel name in relief on one side, and a standard pressure release screw:
    The pump assembly hosts a normal NRV twinned with a simple back-stopped pump cup arrangement. The most interesting feature is the lock-off tab on the inside face of the pump rod knob. The lock tab can be located into a cut-out in the pump tube cap and rotated into a machined groove, similar to what would be used for an internal circlip, to hold the rod in place for travel and to provide limited protection against NRV leakage:
    The tin is original and rather taller than most 1-pint stove tins to accommodate the height of the fixed feet. It is also rather beaten up, but still quite functional:
    And the stove itself is effectively functional:
  2. Rangie
    Rangie Subscriber
    A great dissection as usual Ian @igh371
    A robust, functional stove with some great features :thumbup: :content:
    Now, what tub have you plonked on your Sankey? :whistle: :mrgreen:
    Alec.
  3. igh371
    @Rangie - 107" tub - say no more:D/:-$
    Ian:thumbup:
  4. Robert Bruce
    Springrange NSW Australia
    The tub is defiantly a Landy, could you tell us more about it. Looks like a great restoration project. Oh yes nice stove and it seems quite unusual.
    Oh Landys, as I have a 11a LWB on club reg I am interested in it. I see them a lot and have to restrain my self. Vintage cars are like stoves , a bit addictive. I now have three on the road a good spread, 1924, 1949, and 1968. Some others not restored , comes to mind 1916 and 1926.
    Should stop rambling on.
    Rob
