Handi Oven
Discussion in 'Handi Works Pty Ltd' started by Tony Press, Aug 4, 2018.
  1. Tony Press
    I'm putting this here, but I'm happy if the Moderator(s) think it should be in "Stove Paraffinalia".
    This is, curtesy of @Rodger Willows, my (I think never used) Handi oven. Thanks, Rodger.
    The bottom.
    The baking tray.
    I'm working on the small areas of rust, and I will probably keep this as a shelf queen (which means, I'm now looking for an oven!).
  2. Robert Bruce
    Springrange NSW Australia
    Looks pristine Tony, yes I think it should be on the shelf.
    I to need one of these non collapsing ovens, maby one with a double skin. As you know I have a Coleman oven and it’s good .
    Rob
  3. Simes
    Simes Subscriber
    Very nice indeed.:thumbup:
  4. Brian Whyte
    Brian Whyte United Kingdom Subscriber
    Scotland
    @Robert Bruce how is the Coleman collapsable oven??? My 111kero burns really well but I wondered about fumes or a paraffin taste????
  5. shagratork
    Tony, that is a lovely Handi oven.
    I am happy to leave the thread where it is so that the oven does not get lost in the large Paraffinalia forum.
    There are other ovens in the Handi section of SRG.
    Your oven is similar (but not the same as) Graham's oven.
    However, there are plans to sub-divide the Paraffinalia forum into sub-sections.
    I am not sure when it will happen as it is not an easy task.
    By the way, I have no qualms about unused ovens - I would use it !
  6. Majicwrench
    Majicwrench Subscriber
    Cute!! How large is it??
  7. Ed Winskill
    A properly operating stove produces no kerosene fumes or "taste" whatever.
  8. Brian Whyte
    Scotland
    @Ed Winskill thanks. Was thinking of getting a Coleman foldy one
  9. Ed Winskill
    Brian, definitely get one. There is a lot written, and a lot of photos, on CCS about the Coleman ovens. You will see many examples in a site search.
    The easy portability of the Coleman is where it exceeds other camp ovens.
  10. geeves
    geeves New Zealand Subscriber
    Christchurch NZ
    There is not a lot of Handi branded stuff so I cant see a reason for it not to say here.
  11. Tony Press
    I meant to weigh measure it. I’ll do that later today.
  12. Robert Bruce
    Brian, the Coleman oven on kero or white petrol gives no fumes. I have used it many times and cooks well. The provided thermometer is just an indication and not very accurate but is ok. Also some aluminium foil around the sides but not the back helps.
    Rob
  13. Brian Whyte
    Scotland
    @Ed Winskill @Robert Bruce cheers. I'm in Florida soonish and I'll try and get one cheaper than the UK. Might even bring back 2 :)
  14. Tony Press
    The Handi oven in this post has the following dimensions:
    Height: 23cm (9”)
    Width: 25cm (10”)
    Depth: 23cm.
    With both trays fitted, it weighs 4.35 kilos (10lbs).
  15. shagratork
    It is an identical size to Graham's oven.
  16. Tony Press
    @shagratork
    For all intents and purposes it's the same oven; just a different door handle, and the latch is bent differently.
    What do you reckon, @Graham P ?
  17. z1ulike
    That's a beauty. I really like the enamel coating. If you ever try it out, I'd be interested to know how it performs.
  18. Majicwrench
    Just measure my Coleman oven,11.5 inches wide, 11.5 deep, and 12 inches high, so pretty much the same thing.
