Handy campers' stove
Discussion in 'Japan' started by Doron Papo, Feb 18, 2011.
  1. Doron Papo
    Doron Papo Subscriber
    Hi
    My new find today at the flee market a complete Handy campers' stove
    Here is a close up of the label
    and as it was used before added some fuel and pre-heated
    and burns strong
    and with a pot.
    Does any one collect these?
  2. hikin_jim
    They have a reputation for being dangerous I seem to recall. :shock:
    HJ
  3. CWilkins
    CWilkins Subscriber
    Hello,
    I have several of these stoves. They are quick hot burners good to heat up a pot of water. You have no control over the flame it just burns and surges to a constant roar. The problem with them is that you must extinguish them by a quick blow of air to the coil. Then losen the tank cap. Right after you extingush the flame the fuel will come out of the coil as a gas then a liquid. So just losen the cap and relieve the pressure. The cork is there to plug the hole in the coil when the tank is full of fuel. When you seal the tank cap and fuel remains in the tank the heat from where ever you store it (your trunk, backpack etc) will pressurize in the tank and if there is no cork the fuel will run out. Just like a SEVA 123 when you warm the tank with your hands to push out the fuel for primming.
    They suffer from stress fractures like any other brass tank so keep an eye out.
    Chuck
  4. hikin_jim
    Isn't that dangerous to loosen the cap when the stove is hot?
    HJ
  5. The Bird
    The Bird Subscriber
    Hello Jim,
    I too have one, and take it with me every time I travel distances. I use it to brew up at the roadside, to break a journey. I have no issues with it, as long as I don't open the tank before I have snuffed the flame. I keep it in an Ammunition Box, along with a Sirram Kettle, and the necessary supplies. It serves me very well, and is in many ways as capable as my Primus 71.
    As stated above, it is a great little boiler, but is completely uncontrolled. As safe as the person using it, so as long as it is respected for what it is, no worries. Fun to use, and very quick to get going.
    I can recommend them, as long as all due care is taken, and they are well maintained.
    Best regards,
    Mike.
  6. nzmike
    I had an identical one, I quite liked it, it was nothing if not enthusiastic, but that wasn't to say I trusted it an inch. You have to admire it's simplicity tho, no moving parts and only one seal to keep an eye on.
  7. DAVE GIBSON
    DAVE GIBSON Subscriber
    i have two like this,after a few trys and the "problem" with putting it out i now use them as bookends.
  8. yonadav
    yonadav Subscriber
    The safest way to put it out is to pour some cold water on the tank.
    I have an identical one, also from the local flea market. It has a small crack in the tank, so I keep it for display only.
    Yonadav
  9. itchy
    I now have a few of this design and I think the concept is good, but the manufacturing quality of the product may not always be.
    They are quick to light, run very hot for such a small stove, and fun to use for a quick boil. Obviously not a good choice if you need to "cook" something since there is no simmer and the tank gets really hot quickly.
    The blowing-out-flame followed by venting is probably safe enough because vapor continues to spew until the pressure is released. So if it were going to reignite it would do so before you released the pressure. Never-the-less, the margin for error does seem small.
  10. shagratork
    Hi Doron
    Nice example of that type of stove.
    I have a number of them with different names.
    I think that type of windshield was put on the later versions.
    I have never seen one with its box - brilliant!!!
    I have used them successfully lots of times.
    Always make sure you use a relatively small diameter pan on them so that too much heat is not reflected back to the stove.
    And as has already been said for anyone reading this, to extinguish, direct a quick, hard blow at the coil pinhole and then release the pressure - NEVER the other way round!!!
    Nice one Doron!
  11. kerophile
  12. Doron Papo
    I must say I do like it but its play and let go on this one (mixed feelings here)
  13. mbechtel
    Has anybody ever tried one of these with alcohol?
  14. Lance
    As much as your question sets me to thinking i'm fair sure that using alcohol and this stove at the same time would not be a wise choice. Much like using alcohol and driving a car, they really do not mix. :lol: :lol:
    Yes, i know what you meant.
    lance
  15. yonadav
    yonadav Subscriber
    It might come handy for heating Japanese Sake, if that's what you mean...
