Harness solution for carrying a Primus 41
Discussion in 'Stove Forum' started by Robert Radcliffe, Oct 17, 2020 at 5:01 PM.
  1. Robert Radcliffe
    Stockport UK
    I wondered what you good people think of my harness carry solution for my Primus 41 with no handle. I still intend making a basic bent wire handle but the harness will still be needed to keep the stove closed. Its made of finest Sedgwick bridle leather, the same leather I use to make belts.
    20201017_162402.jpg 20201017_162448.jpg 20201017_162616.jpg 20201017_162525.jpg
    Original post here
    1954 Primus 41 roarer.
  2. Murph
    Milwaukee WI, USA
    Absolutely a outstanding bit of work on your part, and you should be right chuffed with your accomplishment!!
  3. Robert Radcliffe
    Stockport UK
    'right chuffed' - not originally from Oldham, England are you Murph? ;)
    I am quite pleased with the solution.
    Regards
    Rob.
  4. Ian
    Ian Subscriber
    West Yorkshire
    Nice leatherwork, but I think your time would have been better spent with a pair of pliers and half a yard of steel wire.
  5. Ed Winskill
    I endorse this solution!
  6. Robert Radcliffe
    Stockport UK
    @Ian I'm going to give that a go but the 41 handle looks quite a precise and complicated item to make.
  7. Surveyor
    Fife
    Looking for a source for belts need about 10 for no2 cookers and pans, hopefully near Wakefield
  8. kerophile
    Hi @Robert Radcliffe . If you were to make a replacement handle to the original pattern the case will be closed and secure with the handle in the upright carry position. The semi-circular terminations of the handle engage and secure in the case lid.
    Image courtesy of S. Molson:
  9. Robert Radcliffe
    Stockport UK
    @kerophile yes I have a complete 41 with wire handle, I was intending making a simpler version of the handle, more like that on a 111, doubting my ability to make the semi circular parts precisely enough. In which case the harness would still be needed.
    My silent burner 41.
  10. kerophile
    Hi @Robert Radcliffe . You have so many lovely stoves....
    Wire is cheap and you are likely a much better wire-bender than you believe.
  11. Robert Radcliffe
    Stockport UK
    Thank you kind Sir. I'm lucky enough to have a wife that tolerates my many obsessions and to have found a few nice stoves over the years.
    As to the wire bending I am hopeful but not confident.
    Best wishes
    Rob.
  12. Murph
    Milwaukee WI, USA
    @Robert Radcliffe , I'm a Yank, through and through, but I spend far more time watching the Beeb via Britbox, American TV shows and the like are hitting the bottom of the barrel these days!
    On a good day, I can pass for a Brit, or a recent transplant from Dublin - makes for fun on St Paddy's Day, don't have to spend a tuppence on stout or single malt for the night, or go home alone, for that matter (when I was young and single!). Been doing this for donkeys, and the ladies don't know I'm feeding 'em porkies all night long!
    Murph
  13. Spiritburner
    Good to have skills to device alternative solutions :thumbup:
  14. Marc
    Marc Subscriber
    Oregon, USA
    Fantastic work. The dark blue and brown leather look wonderful.
  15. Robert Radcliffe
    Stockport UK
    Thank you Marc. Regards Rob.
