Has anyone ever used body filler on a stove?
Discussion in 'Stove Forum' started by Detroithiker, Oct 5, 2019.
  1. Detroithiker United States
    Detroit michigan
    I have a coleman 6F, 412B and a 417B all with heavy pitting inside and some outside the cases, I would like to try to smooth out one of them and repaint it but I'm not sure how well auto body filler will work, any suggestions?
  2. geeves
    geeves New Zealand Subscriber
    You should be able to get a great finish but it wont stand the heat. You might be able to find some high temperature filler or google lead wiping. This was the method used before auto filler was invented
  3. HercL4D2
    HercL4D2 Subscriber
  4. Blueflame
    Blueflame Canada Subscriber
    Montreal Canada
    The JB weld is a good choice. Remember, you will probably paint over it as Coleman did and the paint rarely showed signs of scorching... I have used it.
  5. Detroithiker United States
    Detroit michigan
    Thanks guys
  6. pyro_P Australia
    Westraya
    IMHO, you may be better off using a high-build primer/undercoat, sand back before finish coat.
  7. Detroithiker United States
    Detroit michigan
    Never heard of it, sounds much easier, have you used it before?
  8. theyellowdog
  9. pyro_P Australia
    Westraya
    Yes, the spray can used was called 'Primer Filler' and after sanding, worked very well under the finish coat.
  10. snwcmpr
    snwcmpr Subscriber
    Thank you for the tip.
  11. Detroithiker United States
    Detroit michigan
    This is gonna help a lot thanks
