Hasag Wick Stove
Discussion in 'Stove Forum' started by Tom Pedersen, Aug 6, 2020.
  1. Tom Pedersen
    Tom Pedersen Denmark Subscriber
    Denmark
    Hey.
    Has this Hasag wick stove.
    Can anyone here at CCS help me with identification?
    It lacks the wick, can it be obtained, and where?
    I will be happy for information on it.
    Thanks and good day to all.
    Tom
      File size:
      163 KB
      50
      File size:
      151 KB
      49
      File size:
      124.8 KB
      49
      File size:
      148.3 KB
      52
  2. presscall
    @Tom Pedersen
    I’m not familiar with that particular stove but the design incorporating concentric perforated burner cylinders is common to other brands I have, such as Chalwyn.
    I can’t tell from the photos (unscrewing the burner from the fuel tank and peering inside would reveal the arrangement) but I assume it’ll have a cylindrical wick with a metal ladder rack mounted in it to engage with a toothed pinion on the wick raiser spindle.
    I buy wicks from the Base Camp but there are other sources of course. The diameter would be determined by the wick mount.
  3. Tom Pedersen
    Denmark
    @presscall
    Thanks for the answer.
    I have tried if I could find something, and have talked to hytta.de in Germany.
    Coincidentally, he himself had a similar one, so I think the problem is solved this time, otherwise I will return.
    Tom
  4. Tom Pedersen
    Denmark
    @presscall
    Hey.
    Sends just a few pictures that you might be able to see something from.
    I'm having trouble finding head and tail in the website you referred
    to. If you can send me a picture and possibly an order number
    on the wick I will take you with me in my evening prayer.
    Sincerely
    Tom
  5. presscall
    @Tom Pedersen
    You seem to have the right idea, of finding a tubular wick of that internal diameter to slide up and down (controlled by the wick raiser rack/cog) on the centre draught tube.
    Here’s an equivalent, a Parasene wick stove.
    The wick and wick carrier (you’ll need both).
    Centre-draught tube.
    Sliding the wick down the tube.
    Tubular wick inner diameter, one-and-a-half inches on this British pre-metric example.
    Showing how the wick raiser cog engages with the rack (series of holes) in the steel wick carrier.
    How that assembly mounts on the stove (wick absent in this photo).
    The chimney component.
    I don’t have access to a parts catalogue for the stove, so I’m unable to.
    You need to have a discussion (maybe swap emails) with a supplier such as Base Camp, because wick and wick carrier are needed. The pitch of the ‘rack’ holes is a factor, but there’s a lot of clearance in a mechanism of that sort, so it shouldn’t be critical.
  6. Tom Pedersen
    Denmark
    @presscall
    Thank you so much John for your great work in explaining to a beginner how a wick stove works.
    I really appreciate it.
    Lovely informative with all the pictures.
    Tom
  7. presscall
    You’re most welcome @Tom Pedersen
    Good luck in your search for a wick and wick carrier to fit your Hasag. It’s a design that puts out a lot of heat. Clean blue flames, chimney internal components glowing red, a silent, odourless powerhouse.
  8. Tom Pedersen
    Denmark
    @presscall
    Hello John.
    Thanks for your help.
    I have now got my Old Hasag to work.
    Had a conversation with hytta.de who had the wick, it
    was too big though, but my wife is good at a sewing machine so she coped with the problem.
    I made the wick carrier myself from a metal bottle that fit the dimension..
    The Hasag is incredibly effective, and boils 1 liter of water on
    a little over 3 minutes.
    Best regards and thanks for all your help John.
    Tom
  9. Tom Pedersen
    Denmark
    A few pictures after the renovation of the Hasag stove.
    Tom
  10. presscall
    @Tom Pedersen Very well done Tom and Mrs Pederson! Great work. Certainly worth the effort, a lovely stove.
  11. Harder D. Soerensen
    Denmark
    Well done Tom!
  12. Tom Pedersen
    Denmark
  13. Tom Pedersen
    Denmark
  14. G1gop
    Cheshire UK
    This is the second post I do not get the images yet I can see all other images in the thread?
    Any one any idea why?
    Alan
  15. Tom Pedersen
    Denmark
    @G1gop
    Hi Alan.
    I do not understand.
    I see them clearly on my PC.
    I'm trying to upload the pictures again in the order mentioned.
    Hope it is better.
    Tom
  16. presscall
  17. G1gop
    Cheshire UK
    Yep I see them
    I just don't understand why I am not seeing some images.
    It's the same on both the phone (android) and computer (firefox).
    Alan
  18. Tom Pedersen
    Denmark
    @G1gop
    Hey.
    Firefox is probably the problem.
    Have seen several posts here on CCP that the site here has issues with Firefox.
    Tom
  19. G1gop
    Cheshire UK
    It could well be, but what puzzles me is that it is only some images that don't show. So I am puzzled what setting needs 'fine tuning'. If the images have been uploaded to CCS, then they should be the same as all others that show.So I am assuming that something about those images is causing the problem (NOT saying it's the images fault, just it seems reasonable to see whats different with them). @Tom Pedersen could you pm me a copy of the images? Perhaps I can trace what is causing the problem. That way it takes this off the thread.
    Alan
  20. Jeopardy
    Jeopardy Subscriber
    I’m seeing the same as @G1gop but on iPhone
    Regards
