Help with a BernzOMatic ST805
Discussion in 'Fettling Forum' started by Spencer Zuraski, Oct 13, 2019.
  1. Spencer Zuraski United States
    West Virginia
    Bought this Bernzomatic ST805 at a garage sale, it doesn't have knobs for the flame control and came with a dry rotted hose. To solve the hose problem, I bought a Mr. Buddy propane regulator to replace the hose and then used 3/8 to 1/4 reducer to fit the stove. I tightened everything up and turned on the gas but nothing came out of the jets. Found a leak from the reduce to the stove itself. I took the hose connection off and it seems that the stove's male end isn't the same as the 1/4 female connection on the reducer. I didn't realize when I put it together because it went together fairly smoothly. Dumb mistake.
    Is there a different style of thread close to 1/4in size out there? A friend of mine who knows a bit more about machining etc. said the threads could be British Whitworth. Is that common for a stove made in Denmark?
      File size:
      215.4 KB
      54
      File size:
      124.3 KB
      50
      File size:
      159.2 KB
      48
      File size:
      97.7 KB
      53
      File size:
      176.5 KB
      47
