Help with an old Soviet stove?
Discussion in 'Stove Forum' started by n736ra, Dec 8, 2021.
  1. n736ra United States
    seattle
    My partners family is from Ukraine, and after visiting them just recently she brought be back this as a present. I've done a little bit of digging on them but don't know exactly what to search for. Was wondering if anyone else here has one and has a set of startup instructions? I've gotten it to light, but never hot enough to start the burner. So I'm not sure if its losing pressure somewhere, or if I'm not pumping it enough, or what.
    It came with all the original paperwork, however, it is all in Russian (obviously she could translate but things might get missed etc).
    Other than this stove my only similar experience is with the Optimus Hiker line (of which I have one).
    Thanks for any help!
  2. presscall
    It’s a Shmel 3 stove.
    I have the single burner version, a Shmel 2. You may care to read my review of it HERE.
    The stoves run too poorly (yellow flames and difficult priming) on kerosene but white gasoline assures reliable priming and combustion. I suspect the ‘dual fuel’ they’re credited as capable of burning is - as with some contemprary Coleman stoves - pump gasoline and white gas, not kerosene and gas.
  3. n736ra United States
    seattle
    thanks! would you mind reposting the link for the first one? It seems to link back to the homepage. I'm trying it with white gas at first
  4. snwcmpr
    Here is a link to the Russian stove gallery.
    Russia/USSR
  5. gieorgijewski
    gieorgijewski Subscriber
    I have no problem with that stove
    But it is not winter stove.
    Only autofuel or whitegas
    Allways You must remember
    1 no leaks losts of pressure
    2 minimum half tanks fuel
    3 longer preheating
    4 tank must be not cold
  6. gieorgijewski
    And two burner work gives more heat to tank ... better pressurised
  7. n736ra United States
    seattle
    whats the best way to preheat it the burners? and how many pumps or so to get it pressurized correctly?
  8. gideon
    usual method to preheat it with meth
    tank volume is 1.8l and it need to do about 100 strokes of pump
    i was doing this stoves at the facility
  9. gideon
    by the way. few days ago one of my friends asks me to restore that stove and i have denied. and what is the cause? there was a time between 1991-1994 when body of burners and pump cylinder was made of steel if wasn't brass at the facility. check yours. also bells can be not soldered to burner, just pressed. check it too.
  10. n736ra United States
    seattle
    ahh good to know, thanks! I think my pump cylinder is brass so in theory all good there.
  11. burny pyromaniac Netherlands
    Arnhem
    My shmel-2 preheats easily on one serving of meths, but indeed good pressure is essential. Pumping takes care. In other threads others have already suggested ways to improve the pumprod. Once well pressurised it goes very well. My bumblebee served well last summerholiday. E5C41C42-FCF4-4B1C-913D-EE4A9637F958.jpeg greetings, Tonio
  12. n736ra United States
    seattle
    Thanks for all the help guys! Got both burners going this afternoon!
    Also went through the documentation that came with it and I believe it's from 1980.
  13. n736ra United States
    seattle
    does anyone have a source for the handles on these stoves? with two burners a second handle would be nice to have
  14. pau-i-amor
    pau-i-amor Subscriber
    17190 Salt, Catalunya
  15. Laitch
    Laitch Subscriber
