Hipolito No 2 query
Discussion in 'Stove Forum' started by seajay, Jan 21, 2020.
  1. seajay
    seajay Subscriber
    Illawarra, NSW
    Hi
    I am in the process of fettling an Hipolito No2 stove with a silent burner and removable legs (sadly missing).
    1. Can someone please tell me if a washer is normally placed between the riser tube and the tank? When I removed the riser tube there was old 'gunk' present but I am not sure if this was the remains of an old washer or accumulated debris.
    2. There was no lead washer under the NRV. Can a Viton washer be used instead
    3. Short of finding a set of Hipolito legs, does anyone know if legs from another stove manufacturer will be suitable replacements.
    Thanks
  2. Tony Press
  3. seajay
    seajay Subscriber
    Illawarra, NSW
    Thanks again
    Regards
    Chris
  4. seajay
    seajay Subscriber
    Illawarra, NSW
    Base camp does not have the correct legs, and as they were longer than the standard Optimus legs, Mike 'the stove' is unable to help.
    If anyone has 3 orphaned Hipolito removable legs I would be grateful if they would let know
    Thanks
  5. Simes
    Simes Subscriber
    @seajay John if all else fails then you can always make your own, CCS have detailed instructions.
    Making Replacement Legs
    There may be No. 2 owners who may be happy to provide dimnsions you can follow.
    A site seach for 'legs' will also throw up some other resources.
  6. seajay
    seajay Subscriber
    Illawarra, NSW
    Thanks.
    In my dreams last night I came to the same conclusion and will give making them a go.
    Regards
    Chris
  7. Tony Press
  8. Harder D. Soerensen
    Denmark
    4E0B34C3-8A9C-4372-ADF1-56648C4356F5.jpeg I dont know if the Hipolito 2 is similar to a Hipolito 1 when it comes to stove legs - but the H1 can use the legs from a primus 210.
    Left: Primus 210
    Right: H1
  9. Tony Press
    Hipolito No. 2 legs:
    Dimensions: 6mm diameter rod; 175mm height.
    @seajay
  10. kerophile
  11. Tony Press
    :thumbup:
  12. seajay
    seajay Subscriber
    Illawarra, NSW
    Thank you all for your replies. This will be added to a growing list of projects and I will let you know how things
