Home made burner bell and plate for a '96'
Discussion in 'Fettling Forum' started by Twoberth, Dec 6, 2017.
  1. Twoberth
    leicestershire, England
    Hi,
    I bought a cheap hand bell souvenir on holiday, as it was made of plated steel and looked suitable for a home made burner bell for a '96' stove. You can buy the equivalent on ebay for a few pounds/dollars/Euros.
    After drilling a hole in the base (top?) to match the lipstick burner head, I cut the hand bell down to size, and file four notches for the burner plate to fit on. I then drilled and filed some air holes and slots, and brazed on a piece of 15mm copper plumbing pipe. Before brazing I slit the cylindrical pipe lengthwise, straightened it and cut off a thin wedge from one of the edges so that it formed a truncated cone when bent back together. By stages, I filed the cone edges until I got a tight friction fit on the lipstick. I then squared the ends and brazed the cut edges back together and onto the bottom of the bell.
    I cut out the flame plate from a piece of brass (from an old tank) to fit in the notches.
    Initially I had only put in the elongated air holes in the bell, but when I lit the stove the flame was blue and yellow/orange, so not enough air. So then I drilled the extra round holes and the flame was much better.
    Total cost 4 Euros. I would probably use thicker brass or steel for the next flame plate. The burner is currently fitted onto a Monitor stove with home-made pot legs to give the correct height. I haven't run it for extended periods, but it works well to boil water for a brew.
  2. hikerduane
    Northern Sierra Nevada
    That was pretty handy. Like most projects we see here, only a hand full of fettlers have the skills, still a good job.
  3. MrAlexxx
    MrAlexxx Canada Subscriber
    Canada
    Excellent bit of work!
  4. Spiritburner
    Great eye spotting the potential of that bell! :thumbup:
  5. Colin Geer
    Colin Geer United Kingdom Subscriber
    Glenfinnan, Highland, Scotland
    Nice retro-fitting! Using that bell was a really good idea!
  6. Jeopardy
    Jeopardy United Kingdom Subscriber
    Good to know that a steel bell will actually work. This type of stove relies on thermal feed back through the bell and the collar into the lipstick. I would have been doubtful that you'd get enough heat transfer though the steel to maintain vapourization of paraffin inside the lipstick.
    Clearly my doubts were unfounded. Well done on a good and tidy looking fettle.
    Regards
  7. ROBBO55
    Nice bit of work . :clap::clap:
  8. Twoberth
    Thanks for your comments. John, I was a bit concerned myself that the heat transfer into the lipstick wouldn't be enough, which is why I made sure that the copper collar was a good fit and made good contact with the lipstick over as large an area as possible.
  9. Murph
  10. Twoberth
    Thanks Murph,
    I remember seeing that post with the brass bell and also a post by Kerophile who modified a plant pot stand for a trivet. Both these posts have changed my mindset when I go to flea markets/car boots - in that I don't just look for stoves, but for other items that I can make stove parts from.
    This brass vase was 20p (30 cents), and I am sure there is a small (or large) roarer flame ring in there somewhere!
  11. kerophile
  12. Twoberth
  13. kerophile
