How to Fix cracks in brass tank??
Discussion in 'Stove Forum' started by Ben85, Oct 13, 2018.
  1. Ben85 Australia
    Cairns Australia
    Does anyone know how to fix cracks I have multiple cracks in a tank or is to unsafe and just use it as sparse
  2. kerophile
  3. Ben85 Australia
    Cairns Australia
    So don’t waste my time with it then thanks for that. I’m just getting starting to get into kerosene stove I have 2 but 1 has cracks and the other has no legs.
  4. Tony Press
    @Ben85
    Welcome.
    Post some photos of your stoves, including the cracks.
    @kerophile is probably correct if your stove has multiple stress-cracks, but it is still interesting to see them.
    We'll be happy here to get you going with your stoves.
  5. Ben85 Australia
    Cairns Australia
    As you can see with my shit soldering I’ve had a go at fixing it.
    43CCDE8E-9A5E-4E40-A674-A3EB9EEB927E.jpeg F5CA3981-DFAE-46D0-9386-FE3C0802044D.jpeg 08F8CD78-9677-4820-892F-DFCFA67C113F.jpeg FC20904C-2ADC-4367-B020-961E13FA832F.jpeg 9D373F7A-B5E8-48BB-B5B0-F5F50C29515B.jpeg F6B5AC59-2B1D-4E52-B5A1-EA750B2C84AF.jpeg
  6. Tony Press
    @Ben85
    I’ve never seen a Companion with multiple stress cracks like that. Does it leak with kero in it?
  7. Ben85 Australia
    Cairns Australia
    Big time
  8. Tony Press
    @Ben85
    The words “big time” means find another tank... Companion tanks are pretty common.
    Can you photograph any tank or part markings? I’m interested in knowing whether this is a very early or very late Companion as they are usually of the highest order of manufacture.
    Best regards
  9. ROBBO55
    @Ben85
    G'day Ben,
    BUGGER !
    Tony, In the fourth picture the Companion shield (not Svea) can be seen above the pump tube.
  10. Ben85 Australia
    Cairns Australia
    That’s it how I got it.
    5ECF8C9D-6D86-4E9E-94D5-9B2F89554A37.jpeg F4B121FB-7E4D-41B2-AE4F-3DDF9B03A958.jpeg 0E0BA529-0B75-428D-874B-72B2B0600121.jpeg A56631D7-5709-45B8-881D-18C75F6C26F1.jpeg
  11. Ben85 Australia
    Cairns Australia
    The other one is a radius No 1.s:or
  12. Marc
    Marc Subscriber
    Oregon, USA
    Welcome to CCS!
    Before you attempt more soldering, I would advise MUCH more cleaning. Solder is like TIG welding, must be absolutely clean for any kind of positive results.
  13. Ben85 Australia
    Cairns Australia
    Think I’ll give up on this one
  14. Marc
    Marc Subscriber
    Oregon, USA
    Set it aside for awhile, you may decide to come back to it.
  15. ROBBO55
    @Ben85
    G'day Ben, to help answer Tony's question is the underside of the spirit cup marked Companion like this one?
    But I suspect it won't be.
    Hopefully you will have more success with the Radius. :lol:
  16. Ben85 Australia
    Cairns Australia
    I had a look but there was nothing
  17. Graham P
    I could supply a tank for cost of post if you wish as I would not be willing to trust a weakened tank with pressure + heat + flamable fuel and a roaring flame. a failure would not be nice
    A really good clean of the area to be soldered is necessary I would use 0000 steel wool and resin core solder
    Or better still low temp silver with the right flux CIG or other similar, even with the solder you used it looks like you need a larger soldering iron or a small gas torch.
    The silver solder is a lot stronger than resin core or plumbers solder.
  18. Ben85 Australia
    Cairns Australia
    Hi graham thanks for your generosity. There’s 6 cracks maybe more I’m going to use it for parts the radius needs legs and the nrv is rounded. I could practice soldering on it to.
