Ilsa Moka Pot Adapter
Discussion in 'Stove Forum' started by Spork, May 10, 2014.
  1. Spork
    I’m one of those unfortunates who doesn’t own one of the fabled MSR Espresso Stars :roll: Thanks to another member’s post about a simmer plate made by Ilsa…I discovered that they also make a stove ring adapter - Ilsa Burnished Steel Adapter
    It’s stamped carbon steel and weighs in at 3.25oz/91g. I’m going to file some shallow notches in the rim to index and center the adapter on my Whisperlite and Rapidfire.
    On a Dragonfly...
    It even works with a Trangia 28...
  2. Jeopardy
    Jeopardy Subscriber
    I have an Indian copy that came as a bundle with a three and a six cup moka pot from Amazon. It also works in a Trangia 27 as I found to my surprise.
    Regards
  3. loco7stove
    loco7stove Subscriber
    That sure is a nifty bit of kit :D/ , have you tried it on a 96 type stove as a pan ring maybe ideal for one :?: :D :thumbup:
    Stu :D :thumbup:
  4. Spork
    I haven't got a 96 type...yet! :D The adapter has fit on about every stove I've tried so far.
  5. kerry460
    kerry460 Australia R.I.P.
    G,,day . I had the thought that the clip on mesh pot support for an optimus 99 could very well work here as well. :-k
    right size mesh and correct placement of nuts and bolts.. :-k
    cheers
    kerry
  6. Spork
    Another option is a grill for a Japanese Konro - Korin - available in a variety of sizes.
  7. Jeopardy
    Jeopardy Subscriber
    As described above, these plates fit a T27 very nicely.
    regards
  8. Sparky
    Sparky Subscriber
    Houston, Tx area
    I will be very interested to see how well the carbon steel stamped plates hold up. If they consistently get red hot, they will oxidize and soften to the point of sagging. The trivets in the tripod stoves do not seem to get red hot since the burner is centered under a large opening. I bought some 1/2" stainless mesh and cut it to fit between the pot supports on an 8R and a 111T. Being stainless, it does not oxidize as quickly when very hot.
  9. GTD.
    I use an old 180mm stainless steel brake disc/rotor from my mountain bike in my Trangia 25s
    Here it is with my 2 cup (or in my case one big mug) Bialetti Mukka Express cappuccino maker.
    I don't need a seperate support when I use it with my Trangia 27s.
  10. kerry460
    good idea :thumbup:
    kerry
  11. bajabum
    bajabum R.I.P.
    Great idea, has a Sci-Fi look to it!
  12. tetley
    what's the burner and what fuel is under the brake disk? :content:
  13. GTD.
    It is a Trangia Multifuel X2 (Primus Omni) running on Panel wipe.
